Forum Header
stepconf and 2.8.0.pre incompatible ?
11 Apr 2017 06:31 #91168
by wicki
stepconf and 2.8.0.pre incompatible ? was created by wicki
is it possible, that ./bin/stepconf of LINUXCNC - 2.8.0~pre1
is unable, to create an config, which is usable by LINUXCNC - 2.8.0~pre1 ?
Machine configuration directory is '/home/ixxx/linuxcnc/configs/machine'
Machine configuration file is 'machine.ini'
check_config: ERROR
Missing [KINS]KINEMATICS=
Missing [KINS]JOINTS=
check_config validation failed
check_config: ERROR
- Thank you received: 5923
12 Apr 2017 00:17 #91215
Same version?
You mean usable by older versions, right?
I am using a lot of older configs that i had no troble when converting to 2.8 by the included script.
It looks like your ini file is missing the kinematics section, check if you have it in the hal file and add it to ini, then try again converting it.
I had an old config like that.
Replied by tommylight on topic stepconf and 2.8.0.pre incompatible ?
Same version?
12 Apr 2017 04:06 #91222
by wicki
Replied by wicki on topic stepconf and 2.8.0.pre incompatible ?
my fault...
I think, I mixed to much different versions, paths and configs....
its working now.
its working now.
- julio cesar
18 Mar 2022 13:45 #237637
by julio cesar
Replied by julio cesar on topic stepconf and 2.8.0.pre incompatible ?
como lo solucionaste?, en mi caso descargue una configuraciĆ³n y cuando intento correrla me sale ese error. ya no se que hacer
Time to create page: 0.137 seconds
