Forum Header
Mach3 XML and Stepconfig issues.
- Thank you received: 1369
19 Apr 2017 18:43 #91665
Replied by Todd Zuercher on topic Mach3 XML and Stepconfig issues.
Just remember when you edit acceleration and feed rates in the ini config file, that those numbers are in units/second. So for max feed rate for example on an inch machine 10 will be 600ipm.
19 Apr 2017 19:35 #91668
by tecno
Replied by tecno on topic Mach3 XML and Stepconfig issues.
OK, thanks for the info.
20 Apr 2017 17:19 #91703
by tecno
Cant find module encoder.update-counters
20 Apr 2017 17:29 - 20 Apr 2017 17:32 #91705
Like I said I'm sure I missed some lines for setting up the encoder.
The line:
addf encoder base-thread
should have been:
addf encoder.update-counters base-thread
The line:
should have been:
Last edit: 20 Apr 2017 17:32 by Todd Zuercher.
20 Apr 2017 17:36 #91706
by tecno
Still cant find module.
How important is that all addf, setp are in one section
20 Apr 2017 17:44 #91707
Setp doesn't matter much (if at all.)
But the addf lines, their order is important. It is important that they are at the begining, but after the loadrt lines. They are executed int the order they are listed. So their order can be very important.
I think you want all of the base-thread addf lines first and where things like reading and writing to the parallel ports are important to be in the right places.
20 Apr 2017 17:49 #91708
by tecno
This is how looks like now. Will leave my shop for now and try again tomorrow.
If you can do some cleaning up I learn how things are placed in hal.
Cheers
Bengt
Cheers
Bengt
20 Apr 2017 17:50 - 20 Apr 2017 17:50 #91709
I think I see another error I made.
The line:
loadrt endoder.update-counters
Should have been:
loadrt encoder num_chan=1
sorry
The line:
Should have been:
sorry
Last edit: 20 Apr 2017 17:50 by Todd Zuercher.
20 Apr 2017 17:59 #91710
by tecno
No problems Todd.
This is not the usual stuff as I understand with my stone-age setup.
I am on pension so there is no hurry, and I appreciate all the help I can get.
Will let you know tomorrow
Bengt
Bengt
21 Apr 2017 07:46 - 21 Apr 2017 07:47 #91756
by tecno
Pin encoder.0.phase-Z => does not exist
Last edit: 21 Apr 2017 07:47 by tecno.
Time to create page: 0.203 seconds
