Forum Header
Mach3 XML and Stepconfig issues.
24 Apr 2017 17:26 #91982
by tecno
Replied by tecno on topic Mach3 XML and Stepconfig issues.
Still pulsating that you can hear by ear.
- Online
- Thank you received: 1369
24 Apr 2017 17:26 #91983
Replied by Todd Zuercher on topic Mach3 Xhttps://forum.linuxcnc.org/16-stepconf-wizard/32ML and Stepconfig issues.
The more I think about it Andy is probably right (he usually is). The chip you are using for your analog conversion is made for converting an encoder signal. So it is expecting the step length and step spacing to be equal.
For your direction signal replace this line.
net spindle-ccw <= stepgen.2.dir
with
net spindle-ccw <= motion.spindle-reverse
with
- Online
24 Apr 2017 17:28 #91984
Is is still pulsing using the type-2 stepgen and the phase-a signal?
- Online
24 Apr 2017 17:30 #91985
You'd also need to change this pin
net spindle-cw <= stepgen.2.step
to
net spindle-cw <= stepgen.2.phase-A
to
24 Apr 2017 17:30 #91986
by tecno
Replied by tecno on topic Mach3 Xhttps://forum.linuxcnc.org/16-stepconf-wizard/32ML and Stepconfig issues.
All settings as per your recommendations I can start spindle, Andy's phase = nothing as I have to edit out several lines to get LCNC started.
- Online
24 Apr 2017 17:33 #91987
You should only need to change 3 lines
loadrt stepgen step_type=0,0,1 ctrl_type=p,p,v
to
loadrt stepgen step_type=0,0,2 ctrl_type=p,p,v
to
24 Apr 2017 17:35 #91988
by tecno
Will go down and test that, thanks Todd.
- Online
24 Apr 2017 17:39 #91989
oh, and comment out these 3
#setp stepgen.2.steplen 250000
#setp stepgen.2.stepspace 250000
#setp stepgen.2.dirdelay 35000
24 Apr 2017 17:45 #91990
by tecno
Still acting as a bad two-stroke.
24 Apr 2017 17:50 #91992
Replied by andypugh on topic Mach3 Xhttps://forum.linuxcnc.org/16-stepconf-wizard/32ML and Stepconfig issues.
Can you look a the parport pin with the halscope again? We should be seeing a 50% square-wave now.
Time to create page: 0.447 seconds
