Forum Header
Simulation of codes ok - but the machine doesn't move
- elevalther
23 Apr 2017 14:10 #91886
by elevalther
Simulation of codes ok - but the machine doesn't move was created by elevalther
Hi Folks
I'm new to Linuxcnc.
I've installed linuxcnc and I have been able to stepper motors to move in the step conf wizard mode, but when I try with a example file nothing happens, I can see the simulation of gcodes is ok, but the machine doesn't work, any idear
br
Elevalther
br
Elevalther
- Thank you received: 5874
23 Apr 2017 16:58 #91892
Replied by tommylight on topic Simulation of codes ok - but the machine doesn't move
On the second screen in stepconf wizard, do not tick the "create simulated hardware configuration".
The following user(s) said Thank You: elevalther
- elevalther
23 Apr 2017 20:45 #91905
by elevalther
Replied by elevalther on topic Simulation of codes ok - but the machine doesn't move
Hi Tommylight
Thanks for your quick response, but unfortunately it was n't the problem, I haven't still not connect any of the input - Estop, Limit switches, homing switches, etc., but all the input pins are set to unsused
Do you have other idear
br
elevalther
br
elevalther
23 Apr 2017 21:11 #91906
If you made a config using stepconf wizard, use that config not a sample config.
If they work in wizard they will work in axis or gmoccapy.
Can you give us more info on the procedure, please.
25 Apr 2017 16:17 #92070
Why are you using an example file rather than the config made by stepconf?
Also be aware that the stepconf axis test does not control the drive-enable pins, so it is sometimes the case that the generated config turns _off_ the drives which worked perfectly OK in the axis test.
Replied by andypugh on topic Simulation of codes ok - but the machine doesn't move
Time to create page: 0.082 seconds
