- Configuring LinuxCNC
- StepConf Wizard
- need help setting up, and troubleshooting config for a 48" X 48" X 5" router
Forum Header
26 Jun 2017 09:18 #94965
by travis036
Replied by travis036 on topic need help setting up, and troubleshooting config for a 48" X 48" X 5" router
sorry for the lack of detail.
direct drive ball screws. i am not sure what the screw pitch is, the company website just refers to the last number in the model number, and that is 5.
please forgive me, i have a woodworking background, not machining.
thanks guys for your help so far.
~Travis
~Travis
- Thank you received: 5906
26 Jun 2017 10:11 #94972
Replied by tommylight on topic need help setting up, and troubleshooting config for a 48" X 48" X 5" router
That should be 5mm pitch, so 40 steps per milimeter. You can set that in stepconf as described above, or enter 320 steps per revolution and everything else at 1.
Preferably you shoule set it as 200 steps, 8 microsteps, 1:1, and 5mm.
If you edit the ini file, 320 for the scale.
Also adjust acceleration accordingly, start at 100mm/s/s , but i would not go above 500 for a mill.
26 Jun 2017 10:21 #94974
by travis036
sorry, i should have said, it is a 48" X 48" X 5" (working area) router table, not a mill.
i will make those settings after work.
Many thanks for your help so far
~Travis
~Travis
26 Jun 2017 13:02 #94983
Sorry as i read that before, so 300 to 700 on acceleration should do just fine.
30 Jun 2017 21:30 #95251
by travis036
well, it has been a little while, but i think i have things sorted out with the configuration. I had to reverse the wiring for the Y axis (never noticed it before), but i got that sorted out. I am planning a dry run tomorrow with a simple G-code program to verify everything is good.
I wasn't sure how to set the soft limits, but i homed the CNC, and then jogged the axis to near the end, and made a note of the value. i then entered that into the configuration. seems to work.
Anyway, i would like to give those who helped a huge thanks
~Travis
~Travis
- StepConf Wizard
Time to create page: 0.079 seconds
