Forum Header
Latency Test is weak...
13 Mar 2024 17:16 #295838
by Topi69
Latency Test is weak... was created by Topi69
Hello everyone,
I guess this Latency Test below very-very bad!!!
Under stepper config axis test the motor lost step if mouse move...
Please recommend me right PC configuration.
Thank You!
Thank You!
13 Mar 2024 17:37 - 13 Mar 2024 17:41 #295841
by Topi69
Replied by Topi69 on topic Latency Test is weak...
Last edit: 13 Mar 2024 17:41 by Topi69. Reason: missing the attachments
13 Mar 2024 20:13 #295851
Replied by PCW on topic Latency Test is weak...
What hardware are you running?
Do you have all power management/cstates>1/Turbo modes/EIST/hyperthreading
disabled in the BIOS?
14 Mar 2024 11:38 #295892
by Topi69
Hi PCW,
I found this information on PC.
Is that enough or do you need more?
What linux terminal command should I use?
14 Mar 2024 16:11 #295908
The settings I mentioned are set the BIOS setup screen on the PC, Not Linux
The following user(s) said Thank You: Topi69
15 Mar 2024 10:28 #295951
by Topi69
Hi PCW,
You wrote this:"Do you have all power management/cstates>1/Turbo modes/EIST/hyperthreadingdisabled in the BIOS?"
Where i find those (about hyperthrading) BIOS informations?
(- I start the boot process,
- I press F10 for BIOS setup
- In the BIOS I found this about power management (see the attachement))
What I make wrong?
Thx!
What I make wrong?
Thx!
- Thank you received: 5944
15 Mar 2024 12:00 #295954
Replied by tommylight on topic Latency Test is weak...
All disabled.
15 Mar 2024 17:34 #295983
by Topi69
I found more informations for my PC,and I have one question:
This processor on below able for LinuxCnc?
15 Mar 2024 18:48 #295988
It should be OK
Make sure you look for power management options
on all tabs (thermal etc)
15 Mar 2024 19:30 #295993
Pretty sure i have one of those HP in the shop, well i have it for sure as i installed Linux Mint and LinuxCNC on it two days ago, so yes it should work if electronics are OK, and it has a parallel port header on the motherboard that usually comes with the DB25 connector on the back.
Time to create page: 0.219 seconds
