Forum Header
Z-Axis no Ref configurable
25 Apr 2024 10:45 #299058
by Satai
Z-Axis no Ref configurable was created by Satai
Hi everyone,I used to work with linuxcnc 2.7.1 for some time on my self build 3-Axis mill. All axis have Ref-switches and everything worked fine, referencing and working.I got a new PC and wanted to upgrade to the newest linuxcnc. Installation went perfectly smooth and the system is incedibly fast and such.Stepconf however doesn't let me configure a Ref-switch for my Z-axis. X and Y - no problem, I can configure them as on my old system and both axis reference without any problem. On the setup page for the Z-axis however is everything around the ref switch greyed out,
I attached 2 pictures. These configurations were standard from stepconf and even then the Z-axis is greyed out. Any Idea anyone?
Thanks,
Sebastian
Thanks,
Sebastian
- Thank you received: 5966
25 Apr 2024 10:53 #299060
Replied by tommylight on topic Z-Axis no Ref configurable
You have not assigned a pin for the Z axis switch in the pinout page.
25 Apr 2024 13:42 #299067
by Satai
Replied by Satai on topic Z-Axis no Ref configurable
I assigned the pins as seen in the attachment, sorry, forgot to attach it
25 Apr 2024 13:48 #299068
OK then seems to be an issue with StepConf, probably language, but that is only a guess.
The following user(s) said Thank You: Satai
25 Apr 2024 16:41 #299074
by Satai
Thank you anyway.
26 Apr 2024 06:37 #299095
by Satai
Hi everyone,
it's getting a bit more weird today. I managed to use my ref switch in the Z axis as I set it to Ref Z alone without the maximum limit. Set so the axis referenced without any problem.
But then another problem occured: I can't start my spindle, Pin 9 won't be switched, regardless what I try. I tried the Live-version in english without success, both problems persist: Z-axis references only as Ref-alone and my spindle won't start.
I tried the 2.8.4 as a Live-version and everything runs smooth and fine, the Z-Axis and also the spindle.
I thjink I'll install the 2.8.4 this weekend and go on working with it. But the problems that I experience with the actual 2.9.2 are really strange to say the least.
Any suggestions?
Thanks, Sebastian
Any suggestions?
Thanks, Sebastian
26 Apr 2024 12:55 #299116
Try in MDI
M3 $0 S3000
M3 $0 S3000
26 Apr 2024 18:49 #299132
by Satai
No reaction. Gmoccapy assumes that the spindle is running but nothing...
26 Apr 2024 18:58 #299133
Attach the actual hal and ini file here se we can have a look.
26 Apr 2024 19:16 #299139
by Satai
Here we have my ini:
And now for the hal:
# Erstellt von stepconf 1.1 am Fri Apr 26 09:34:25 2024
# Änderungen an dieser Datei werden beim nächsten
# wird überschrieben wenn Sie stepconf erneut ausführen
[EMC]
MACHINE = my-Fräse
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = gmoccapy
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
ARCDIVISION = 64
GRIDS = 10mm 20mm 50mm 100mm 1in 2in 5in 10in
MAX_FEED_OVERRIDE = 1.2
MIN_SPINDLE_OVERRIDE = 0.5
MAX_SPINDLE_OVERRIDE = 1.2
DEFAULT_LINEAR_VELOCITY = 10.00
MIN_LINEAR_VELOCITY = 0
MAX_LINEAR_VELOCITY = 100.00
CYCLE_TIME = 0.100
INTRO_TIME = 5
PROGRAM_PREFIX = /home/cnc/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
[KINS]
JOINTS = 3
KINEMATICS = trivkins coordinates=XYZ
[FILTER]
PROGRAM_EXTENSION = .nc,.tap G-Code File
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
BASE_PERIOD = 69444
SERVO_PERIOD = 1000000
[HAL]
HALFILE = my-Fräse.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
[TRAJ]
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
#*** AXIS_X *******************************
[AXIS_X]
MAX_VELOCITY = 90.0
MAX_ACCELERATION = 700.0
MIN_LIMIT = -0.001
MAX_LIMIT = 200.0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.001
MAX_LIMIT = 200.0
MAX_VELOCITY = 90.0
STEPGEN_MAXACCEL = 875.0
SCALE = 84.03361344537815
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.000000
HOME_SEARCH_VEL = -8.000000
HOME_LATCH_VEL = 5.950000
HOME_IGNORE_LIMITS = YES
HOME_SEQUENCE = 1
#*** AXIS_Y *******************************
[AXIS_Y]
MAX_VELOCITY = 100.0
MIN_LIMIT = -0.001
MAX_LIMIT = 300.0
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.001
MAX_LIMIT = 300.0
FERROR = 1
MIN_FERROR = .25
HOME_SEQUENCE = 2
#*** AXIS_Z *******************************
[AXIS_Z]
MAX_VELOCITY = 17.10010944070042
MAX_ACCELERATION = 180.0
MIN_LIMIT = -120.0
MAX_LIMIT = 0.001
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -120.0
MAX_LIMIT = 0.001
STEPGEN_MAXACCEL = 225.0
SCALE = 800.0
FERROR = 1
MIN_FERROR = .25
HOME_SEARCH_VEL = 4.000000
HOME_LATCH_VEL = -0.625000
HOME_SEQUENCE = 0
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS
loadrt hal_parport cfg="0 out"
setp parport.0.reset-time 5000
loadrt stepgen step_type=0,0,0
addf stepgen.update-freq servo-thread
net xenable => parport.0.pin-01-out
net xstep => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
setp parport.0.pin-03-out-invert 1
net ydir => parport.0.pin-03-out
net adir => parport.0.pin-05-out
net astep => parport.0.pin-06-out
setp parport.0.pin-06-out-reset 1
net zstep => parport.0.pin-07-out
setp parport.0.pin-07-out-reset 1
net zdir => parport.0.pin-08-out
net spindle-cw => parport.0.pin-09-out
setp parport.0.pin-14-out-invert 1
net xdir => parport.0.pin-14-out
net ystep => parport.0.pin-16-out
setp parport.0.pin-16-out-reset 1
net min-home-x <= parport.0.pin-10-in-not
net min-home-y <= parport.0.pin-11-in-not
net home-z <= parport.0.pin-12-in-not
net min-home-v <= parport.0.pin-13-in-not
net estop-ext <= parport.0.pin-15-in
setp stepgen.0.position-scale [JOINT_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 35000
setp stepgen.0.dirsetup 35000
setp stepgen.0.maxaccel [JOINT_0]STEPGEN_MAXACCEL
net xpos-cmd joint.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => joint.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable joint.0.amp-enable-out => stepgen.0.enable
net min-home-x => joint.0.home-sw-in
net min-home-x => joint.0.neg-lim-sw-in
setp stepgen.1.position-scale [JOINT_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 35000
setp stepgen.1.dirsetup 35000
setp stepgen.1.maxaccel [JOINT_1]STEPGEN_MAXACCEL
net ypos-cmd joint.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => joint.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable joint.1.amp-enable-out => stepgen.1.enable
net min-home-y => joint.1.home-sw-in
net min-home-y => joint.1.neg-lim-sw-in
setp stepgen.2.position-scale [JOINT_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 35000
setp stepgen.2.dirsetup 35000
setp stepgen.2.maxaccel [JOINT_2]STEPGEN_MAXACCEL
net zpos-cmd joint.2.motor-pos-cmd => stepgen.2.position-cmd
net zpos-fb stepgen.2.position-fb => joint.2.motor-pos-fb
net zstep <= stepgen.2.step
net zdir <= stepgen.2.dir
net zenable joint.2.amp-enable-out => stepgen.2.enable
net home-z => joint.2.home-sw-in
net estop-ext => iocontrol.0.emc-enable-in
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
