Forum Header
Parport Address
05 Aug 2009 15:36 #682
by alczikk
Parport Address was created by alczikk
I am trying to get started with EMC2. I use a Dell GX240 pc. The BIOS gives 378h as the parallel port address. When I try to use Stepconf to configure I get an error: Parport error bad port address '378h'.When I use 0x0378 as the address, Stepconf works,but when I try to test an axis, the motor doesn't turn. Is it OK to use the address in the form 0x0378, or does that cause a disconnect between the software and hardware? Are the output signals actually reaching the parallel port? Thanks for your help.
05 Aug 2009 23:08 #684
by mozmck
Replied by mozmck on topic Re:Parport Address
The address you should put in stepconf is 0x378
Moses
Moses
06 Aug 2009 11:59 #686
by BigJohnT
Replied by BigJohnT on topic Re:Parport Address
You might have your step and direction pins backward or not have the drive enable or charge pump if your driver has one.
What kind of drive is it?
A bit of info:
www.linuxcnc.org/docview/html//common_Getting_EMC.html#r2_3
A bit of info:
