Forum Header
Slaved axis
10 Aug 2009 07:33 #691
by Greolt
Slaved axis was created by Greolt
Sorry this must get asked all the time. I did search but am new to the forum and did not find what I need.
I am a long term Mach3 user on a number of machines. So I thought I would have a look at EMC2.
One is a gantry router with two drives on the X axis. How do I slave the X with the A (or B or C)?
If it can only be done by hooking two drives to one set of output pins then unfortunately that is a deal breaker for me.
Greolt
Greolt
10 Aug 2009 11:59 #692
by BigJohnT
Replied by BigJohnT on topic Re:Slaved axis
I'm confused as to what your trying to do.
Do you want to drive both sides of the Gantry with X nnn and have seperate parallel port pins for each drive?
Just pick two more pins for X step and direction in the stepconf wizard...
Or are you wanting to drive one side with X nnn and the other side with A nnn?
11 Aug 2009 01:15 #693
by Greolt
Replied by Greolt on topic Re:Slaved axis
OK I got it working as you said.
I was trying to do it all in Stepconf via the "test this axis" dialogue and it would not jog two drives.
However when testing in EMC it worked as expected.
Next question;
How do I alter keyboard shortcuts?
I use a non extended keyboard which has no page-up or page-down keys.
I want to jog Z with + and - keys as I am accustomed to using.
Thanks for answering these very newb type queries.
Greolt
Next question;
Greolt
11 Aug 2009 10:20 #696
by BigJohnT
That is a bit more complicated. Here is a link
article.gmane.org/gmane.linux.distributions.emc.user/12642
Once you make the changes save the changes as an upgrade might overwrite the file.
11 Aug 2009 23:25 #697
by Greolt
Yes that worked.
Thanks John
Greolt
Thanks John
Greolt
Time to create page: 0.137 seconds
