EMC Latency Test
27 Nov 2009 12:35 #1210
by anshuman
EMC Latency Test was created by anshuman
Hello,
I am using Ubuntu installed inside Windows. My PC configuration is Intel CPU 1.6 GHz with 1.24 GB RAM, 2 GB free space on the drive on which Ubuntu is installed. When I run the EMC Latency Test, even without any extra load, the Max Jitter number it gives me is 704,795 for Servo thread and 728584 for Base thread. Even after having better configuration than the one required for EMC, what could be the reasons for getting such high latency numbers?
Regards,
Anshuman
Regards,
Anshuman
27 Nov 2009 14:13 - 27 Nov 2009 14:14 #1211
by Andy123
Replied by Andy123 on topic Re:EMC Latency Test
During last few weeks I was playing with multiple computers and I realized that faster PC does not mean smaller jitter numbers
For example - I am geting excellent results with Inspiron 5000 P3 made in 1999, but it looks terrible with newer Dell Latitude D610 with 2 GB ram and fast video. I know laptops are not recomended, but does it apply to the older models? Does not look like.
I also installed it on P4 1.6A processor system and getting excellent results, but I can't get acceptable jitter on small fanless industriual pc I got.
I am about to get Atom 330 based board (Intel or Asus), but I am afraid I will get same jitter problems.
I am not sure how to handle this, I hope someone with better Ubuntu experience can give us some explanation
Last edit: 27 Nov 2009 14:14 by Andy123.
01 Dec 2009 08:22 #1223
by anshuman
Replied by anshuman on topic Re:EMC Latency Test
I was going through the EMC2 Getting Started file and read about the SMI issues. I wonder if I am having this latency issue becasue of SMI. I have been trying to edit the "rtapi.conf" file according to "EMC Documentation Wiki FixingSMIIssues.htm" to disable the SMI. But the system said that I didn't have permissions even if I am the administrator. I have tried changing the file's permissions using 'chmod +w rtapi.conf' but haven't been able to do so either. How can I edit the file? I am not very familiar with Linux, so any pointers will be appreciated.
Andy, maybe you are also facing problems because of SMI. Do check it out.
Regards,
Anshuman
Regards,
Anshuman
05 Dec 2009 08:23 - 08 Dec 2009 08:19 #1257
by anshuman
I was hoping somebody would reply to this as I am not able to solve this issue. I need to edit the 'rtapi.conf' file so as to disable the SMI as explained in my previous post. But I am not able to edit the file or change it's permissions. I would appreciate any help in this regard.
Regards,
Anshuman
Regards,
Anshuman
Last edit: 08 Dec 2009 08:19 by anshuman.
05 Dec 2009 10:35 #1258
by acemi
Replied by acemi on topic Re:EMC Latency Test
sudo sh
to switch root user account and then try again.
10 Dec 2009 08:25 #1289
by anshuman
Hi acemi,
Thanks for replying. Using 'sudo sh' I was able to edit rtapi.conf file and was able to disable SMI. After that the latency test is showing me sane numbers.
Thanks again.
- Anshuman
Thanks again.
- Anshuman
Time to create page: 0.131 seconds
