PCI Parallel port
25 Jan 2010 12:41 #1630
by anshuman
Replied by anshuman on topic Re:PCI Parallel port
Hi acemi,
Here's the output for 'lspci -v':
anshuman@anshuman-desktop:~$ lspci -v
00:00.0 Host bridge: Intel Corporation 82945G/GZ/P/PL Memory Controller Hub (rev 02)
Subsystem: Elitegroup Computer Systems Unknown device 2633
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
00:02.0 VGA compatible controller: Intel Corporation 82945G/GZ Integrated Graphics Controller (rev 02) (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 10
Memory at fea80000 (32-bit, non-prefetchable) [size=512K]
I/O ports at dc00
Memory at d0000000 (32-bit, prefetchable) [size=256M]
Memory at fea40000 (32-bit, non-prefetchable) [size=256K]
00:1b.0 Audio device: Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller (rev 01)
Memory at fea38000 (64-bit, non-prefetchable) [size=16K]
00:1d.0 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #1 (rev 01) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 5
I/O ports at d880
00:1d.1 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #2 (rev 01) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 11
I/O ports at d800
00:1d.2 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #3 (rev 01) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 15
I/O ports at d480
00:1d.3 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #4 (rev 01) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 10
I/O ports at d400
00:1d.7 USB Controller: Intel Corporation 82801G (ICH7 Family) USB2 EHCI Controller (rev 01) (prog-if 20 [EHCI])
Memory at fea37c00 (32-bit, non-prefetchable) [size=1K]
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1) (prog-if 01 [Subtractive decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=32
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: feb00000-febfffff
00:1f.0 ISA bridge: Intel Corporation 82801GB/GR (ICH7 Family) LPC Interface Bridge (rev 01)
00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 01) (prog-if 8a [Master SecP PriP])
I/O ports at 01f0
I/O ports at 03f4
I/O ports at 0170
I/O ports at 0374
I/O ports at ffa0
00:1f.2 IDE interface: Intel Corporation 82801GB/GR/GH (ICH7 Family) SATA IDE Controller (rev 01) (prog-if 8f [Master SecP SecO PriP PriO])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 11
I/O ports at d080
I/O ports at d000
I/O ports at cc00
I/O ports at c880
I/O ports at c800
00:1f.3 SMBus: Intel Corporation 82801G (ICH7 Family) SMBus Controller (rev 01)
Flags: medium devsel, IRQ 10
I/O ports at 0400
01:02.0 Serial controller: Unknown device 4348:5053 (rev 10) (prog-if 02 [16550])
Subsystem: Unknown device 4348:5053
Flags: medium devsel, IRQ 11
I/O ports at ec00
I/O ports at e880
01:05.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
Subsystem: Elitegroup Computer Systems Unknown device 8139
Flags: bus master, medium devsel, latency 64, IRQ 3
I/O ports at e400
Memory at febffc00 (32-bit, non-prefetchable)
Here's the output for 'sudo lshw':
anshuman-desktop
description: Desktop Computer
product: PI945GCM
vendor: Kobian
version: 1.X
serial: 1131
width: 32 bits
capabilities: smbios-2.5 dmi-2.5 smp-1.4 smp
configuration: boot=normal chassis=desktop cpus=2 uuid=00020003-0004-0005-0006-000700080009
*-core
description: Motherboard
product: PI945GCM
vendor: Kobian
physical id: 0
version: ECS
serial: To be filled by O.E.M.
slot: To Be Filled By O.E.M.
*-firmware
description: BIOS
vendor: American Megatrends Inc.
physical id: 0
version: 080012 (05/08/2007)
capacity: 448KiB
capabilities: isa pci pnp apm upgrade shadowing escd cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer int10video acpi usb ls120boot zipboot biosbootspecification
*-cpu:0
description: CPU
product: Genuine Intel(R) CPU 2140 @ 1.60GHz
vendor: Intel Corp.
physical id: 4
bus info: cpu@0
version: 6.15.2
serial: 0000-06F2-0000-0000-0000-0000
slot: CPU 1
capacity: 1600MHz
width: 64 bits
clock: 200MHz
capabilities: boot fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe x86-64 constant_tsc arch_perfmon pebs bts pni monitor ds_cpl est tm2 ssse3 cx16 xtpr lahf_lm
configuration: id=0
*-cache:0
description: L1 cache
physical id: 5
slot: L1-Cache
capacity: 64KiB
capabilities: internal write-back data
*-cache:1
description: L2 cache
physical id: 6
slot: L2-Cache
capacity: 1MiB
capabilities: internal write-back instruction
*-cache:2 DISABLED
description: L3 cache
physical id: 7
slot: L3-Cache
*-logicalcpu:0
description: Logical CPU
physical id: 0.1
width: 64 bits
capabilities: logical
*-logicalcpu:1
physical id: 0.2
width: 64 bits
*-memory
description: System Memory
physical id: f
slot: System board or motherboard
*-bank:0
description: DIMM SDRAM Synchronous
product: PartNum0
vendor: Manufacturer0
physical id: 0
serial: SerNum0
slot: DIMM0
width: 64 bits
*-bank:1
description: DIMM [empty]
product: PartNum1
vendor: Manufacturer1
physical id: 1
serial: SerNum1
slot: DIMM1
*-bank:2
product: PartNum2
vendor: Manufacturer2
physical id: 2
serial: SerNum2
slot: DIMM2
width: 64 bits
*-bank:3
product: PartNum3
vendor: Manufacturer3
physical id: 3
serial: SerNum3
slot: DIMM3
*-cpu:1
physical id: 1
bus info: cpu@1
version: 6.15.2
capabilities: ht
configuration: id=0
*-logicalcpu:0
physical id: 0.1
*-logicalcpu:1
physical id: 0.2
*-pci
description: Host bridge
product: 82945G/GZ/P/PL Memory Controller Hub
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 02
width: 32 bits
clock: 33MHz
configuration: driver=agpgart-intel module=intel_agp
*-display UNCLAIMED
description: VGA compatible controller
product: 82945G/GZ Integrated Graphics Controller
physical id: 2
bus info: pci@0000:00:02.0
version: 02
width: 32 bits
clock: 33MHz
capabilities: msi pm vga_controller bus_master cap_list
configuration: latency=0
*-multimedia
description: Audio device
product: 82801G (ICH7 Family) High Definition Audio Controller
physical id: 1b
bus info: pci@0000:00:1b.0
version: 01
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=HDA Intel latency=0 module=snd_hda_intel
*-usb:0
description: USB Controller
product: 82801G (ICH7 Family) USB UHCI Controller #1
physical id: 1d
bus info: pci@0000:00:1d.0
version: 01
width: 32 bits
clock: 33MHz
capabilities: uhci bus_master
configuration: driver=uhci_hcd latency=0 module=uhci_hcd
*-usb:1
product: 82801G (ICH7 Family) USB UHCI Controller #2
physical id: 1d.1
bus info: pci@0000:00:1d.1
version: 01
width: 32 bits
clock: 33MHz
*-usb:2
product: 82801G (ICH7 Family) USB UHCI Controller #3
physical id: 1d.2
bus info: pci@0000:00:1d.2
version: 01
width: 32 bits
clock: 33MHz
*-usb:3
product: 82801G (ICH7 Family) USB UHCI Con roller #4
physical id: 1d.3
bus info: pci@0000:00:1d.3
version: 01
width: 32 bits
clock: 33MHz
*-usb:4
product: 82801G (ICH7 Family) USB2 EHCI Controller
physical id: 1d.7
bus info: pci@0000:00:1d.7
version: 01
width: 32 bits
clock: 33MHz
capabilities: pm debug ehci bus_master cap_list
configuration: driver=ehci_hcd latency=0 module=ehci_hcd
*-pci
description: PCI bridge
product: 82801 PCI Bridge
physical id: 1e
bus info: pci@0000:00:1e.0
version: e1
width: 32 bits
clock: 33MHz
capabilities: pci subtractive_decode bus_master cap_list
*-communication
description: Serial controller
physical id: 2
bus info: pci@0000:01:02.0
version: 10
width: 32 bits
clock: 33MHz
capabilities: 16550
configuration: driver=serial latency=0
*-network
description: Ethernet interface
product: RTL-8139/8139C/8139C+
vendor: Realtek Semiconductor Co., Ltd.
physical id: 5
bus info: pci@0000:01:05.0
logical name: eth0
version: 10
serial: 00:1b:b9:9a:38:8d
capacity: 100MB/s
width: 32 bits
clock: 33MHz
capabilities: pm bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=8139too driverversion=0.9.28 duplex=full latency=64 link=yes maxlatency=64 mingnt=32 module=8139too multicast=yes port=MII speed=100MB/s
*-isa
description: ISA bridge
product: 82801GB/GR (ICH7 Family) LPC Interface Bridge
physical id: 1f
bus info: pci@0000:00:1f.0
version: 01
width: 32 bits
clock: 33MHz
capabilities: isa bus_master cap_list
*-ide:0
description: IDE interface
product: 82801G (ICH7 Family) IDE Controller
physical id: 1f.1
bus info: pci@0000:00:1f.1
logical name: scsi0
version: 01
width: 32 bits
clock: 33MHz
capabilities: ide bus_master emulated
configuration: driver=ata_piix latency=0 module=ata_piix
*-cdrom:0
description: SCSI CD-ROM
product: CD-ROM SH-C522C
vendor: TSSTcorp
physical id: 0.0.0
bus info: scsi@0:0.0.0
logical name: /dev/cdrom
logical name: /dev/scd0
logical name: /dev/sr0
version: TS03
capabilities: removable audio
configuration: ansiversion=5 status=open
*-cdrom:1
description: DVD-RAM writer
product: DVD-RAM GH22NP20
vendor: HL-DT-ST
physical id: 0.1.0
bus info: scsi@0:0.1.0
logical name: /dev/cdrom1
logical name: /dev/dvd1
logical name: /dev/scd1
logical name: /dev/sr1
version: 1.00
serial: [HL-DT-STDVD-RAM GH22NP201.0008/03/25 7U01
capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ra
*-ide:1
product: 82801GB/GR/GH (ICH7 Family) SATA IDE Controller
physical id: 1f.2
bus info: pci@0000:00:1f.2
logical name: scsi2
version: 01
width: 32 bits
clock: 66MHz
capabilities: ide pm bus_master cap_list emulated
*-disk
description: ATA Disk
product: HDS728080PLA380
physical id: 0.1.0
bus info: scsi@2:0.1.0
logical name: /dev/sda
version: PF2O
serial: PFDB32E8TVR52M
capabilities: partitioned partitioned:dos
configuration: ansiversion=5 signature=0e770e76
*-volume:0
description: Windows NTFS volume
physical id: 1
bus info: scsi@2:0.1.0,1
logical name: /dev/sda1
version: 3.1
serial: 889a20f8-6231-fc4c-8383-c8843c75f0ca
capacity: 17GiB
capabilities: primary bootable ntfs initialized
configuration: clustersize=4096 created=2009-12-31 07:01:14 filesystem=ntfs state=clean
*-volume:1
description: Extended partition
physical id: 2
bus info: scsi@2:0.1.0,2
logical name: /dev/sda2
capacity: 59GiB
capabilities: primary extended partitioned partitioned:extended
*-logicalvolume:0
description: W95 FAT32 partition
physical id: 5
logical name: /dev/sda5
logical name: /host
logical name: /boot
capacity: 19GiB
configuration: mount.fstype=vfat mount.options=rw,relatime,fmask=0022,dmask=0022,codepage=cp437,iocharset=iso8859-1 state=mounted
*-logicalvolume:1
physical id: 6
logical name: /dev/sda6
capacity: 19GiB
*-logicalvolume:2
physical id: 7
logical name: /dev/sda7
logical name: /media/NEW VOLUME
capacity: 20GiB
configuration: mount.fstype=vfat mount.options=rw,nosuid,nodev,relatime,uid=1000,fmask=0077,dmask=0077,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8 state=mounted
*-serial UNCLAIMED
description: SMBus
product: 82801G (ICH7 Family) SMBus Controller
physical id: 1f.3
bus info: pci@0000:00:1f.3
version: 01
width: 32 bits
clock: 33MHz
Regards,
Anshuman
I/O ports at dc00
I/O ports at d880
I/O ports at d800
I/O ports at d480
I/O ports at d400
I/O ports at 01f0
I/O ports at 03f4
I/O ports at 0170
I/O ports at 0374
I/O ports at ffa0
I/O ports at d080
I/O ports at d000
I/O ports at cc00
I/O ports at c880
I/O ports at c800
I/O ports at 0400
I/O ports at ec00
I/O ports at e880
I/O ports at e400
anshuman-desktop
product: PI945GCM
vendor: Kobian
version: 1.X
serial: 1131
width: 32 bits
*-core
product: PI945GCM
vendor: Kobian
physical id: 0
version: ECS
*-firmware
description: BIOS
physical id: 0
capacity: 448KiB
*-cpu:0
description: CPU
vendor: Intel Corp.
physical id: 4
bus info: cpu@0
version: 6.15.2
slot: CPU 1
capacity: 1600MHz
width: 64 bits
clock: 200MHz
configuration: id=0
*-cache:0
physical id: 5
slot: L1-Cache
capacity: 64KiB
*-cache:1
physical id: 6
slot: L2-Cache
capacity: 1MiB
*-cache:2 DISABLED
physical id: 7
slot: L3-Cache
*-logicalcpu:0
physical id: 0.1
width: 64 bits
*-logicalcpu:1
physical id: 0.2
width: 64 bits
*-memory
physical id: f
*-bank:0
product: PartNum0
physical id: 0
serial: SerNum0
slot: DIMM0
width: 64 bits
*-bank:1
product: PartNum1
physical id: 1
serial: SerNum1
slot: DIMM1
*-bank:2
product: PartNum2
physical id: 2
serial: SerNum2
slot: DIMM2
width: 64 bits
*-bank:3
product: PartNum3
physical id: 3
serial: SerNum3
slot: DIMM3
*-cpu:1
physical id: 1
bus info: cpu@1
version: 6.15.2
capabilities: ht
configuration: id=0
*-logicalcpu:0
physical id: 0.1
*-logicalcpu:1
physical id: 0.2
*-pci
physical id: 100
version: 02
width: 32 bits
clock: 33MHz
*-display UNCLAIMED
physical id: 2
version: 02
width: 32 bits
clock: 33MHz
*-multimedia
physical id: 1b
version: 01
width: 64 bits
clock: 33MHz
*-usb:0
physical id: 1d
version: 01
width: 32 bits
clock: 33MHz
*-usb:1
physical id: 1d.1
version: 01
width: 32 bits
clock: 33MHz
*-usb:2
physical id: 1d.2
version: 01
width: 32 bits
clock: 33MHz
*-usb:3
physical id: 1d.3
version: 01
width: 32 bits
clock: 33MHz
*-usb:4
physical id: 1d.7
version: 01
width: 32 bits
clock: 33MHz
*-pci
physical id: 1e
version: e1
width: 32 bits
clock: 33MHz
*-communication
physical id: 2
version: 10
width: 32 bits
clock: 33MHz
capabilities: 16550
*-network
physical id: 5
logical name: eth0
version: 10
capacity: 100MB/s
width: 32 bits
clock: 33MHz
*-isa
physical id: 1f
version: 01
width: 32 bits
clock: 33MHz
*-ide:0
physical id: 1f.1
logical name: scsi0
version: 01
width: 32 bits
clock: 33MHz
*-cdrom:0
vendor: TSSTcorp
physical id: 0.0.0
version: TS03
*-cdrom:1
vendor: HL-DT-ST
physical id: 0.1.0
version: 1.00
*-ide:1
physical id: 1f.2
logical name: scsi2
version: 01
width: 32 bits
clock: 66MHz
*-disk
physical id: 0.1.0
version: PF2O
*-volume:0
physical id: 1
version: 3.1
capacity: 17GiB
*-volume:1
physical id: 2
capacity: 59GiB
*-logicalvolume:0
physical id: 5
logical name: /host
logical name: /boot
capacity: 19GiB
*-logicalvolume:1
physical id: 6
capacity: 19GiB
*-logicalvolume:2
physical id: 7
capacity: 20GiB
*-serial UNCLAIMED
description: SMBus
physical id: 1f.3
version: 01
width: 32 bits
clock: 33MHz
Regards,
Anshuman
25 Jan 2010 21:25 #1635
by acemi
Replied by acemi on topic Re:PCI Parallel port
Maybe this problem is related with ACPI. IIRC, there is no ACPI support in RTAI kernel. If you boot the system with normal Ubuntu kernel (which is not compiled with RTAI), can you see the parallel port with "lspci -v" command?
27 Jan 2010 11:33 #1645
by anshuman
Hi acemi,
I am a Ubuntu newbie, so I don't know how to boot the system with normal Ubuntu without RTAI. Please tell me how to do this or give me a web link which shows how to do this.
Btw, I had edited the rtapi.conf file to disable the SMI. Does this have to do anything with that?
Regards,
Anshuman
Regards,
Anshuman
27 Jan 2010 19:39 - 27 Jan 2010 19:40 #1654
by acemi
Hi Anshuman,
Choose the appropriate boot setting from the grub menu (the blue menu at the boot time)
If you send "cat /boot/grub/menu.lst" command's output, I can say you which one is the non-patched kernel
Last edit: 27 Jan 2010 19:40 by acemi.
Time to create page: 0.073 seconds
