SMP on Jetway NC92-N330-LF... 8169-No Network
23 Dec 2009 04:00 #1372 by cblack
I don't know if anyone else is going to run into this but figured I would post it anyway. I installed the SMP rtai package from linuxcnc.org/experimental/hardy/smp/ and all the sudden my network wouldn't connect. It appears to be a known problem and adding "nopat" to the kernel options seems to fix it..
Just in case someone else runs into it.
23 Dec 2009 23:31 - 23 Dec 2009 23:57 #1381 by Andy123
I guess you are having the same issue I had with Intel Atom 330 motherboard:
Network works one time, next time you reboot - no network
Also if I unplug AC power and wait 1 minute - all comes back until next reboot
Here is a problem:
Linux uses R8169 driver and your chip is actually R8168
To verify it use:
lspci -v
if it is listed as RTL8111/8168B then I have fix that worked for me
www.jamesonwilliams.com/hardy-r8168
Without going into details, simply download script from the link on this page and run it
www.jamesonwilliams.com/bin/r8168_scripts.tar.bz2
It fixed all my problems
I heard it may be similar problem with sound, but I don't use sound on my PC and can't confirm
Edit: It looks like your board has same 8111/8168 chip, so this script will work for you
Last edit: 23 Dec 2009 23:57 by Andy123.
Time to create page: 0.306 seconds
