Using EMC2 with Motion Controller Card for CNC
23 Jan 2010 04:12 #1597
by Hobbydad
Using EMC2 with Motion Controller Card for CNC was created by Hobbydad
Hello Everyone!
I am new to CNC but not to machining, I picked up a piece of equipment from work and I want to change it over for CNC Machining. It has a motion controller card in the computer and connects to the machine with a large 100pin connector. The unit has everything that can be used for cnc except for cutting, it once did very precise printing on microscope slides. It has the x,y & z movement(real nice), Allen Bradley servo amplifiers, an interface and the motion controller in the computer.
What I need to know is will EMC work with a motion controller card or does it need a parallel port? Also if so what would I need in the computer and then would the Allen Bradley motor amplifiers still work? The Servo Amplifiers are 1398-DDM-005. The Motion Controller card is a ISA slot Optomised Controler LTD brand card that is now owned by Baldor. The Motion Controler card is a NMP002-523.
Thanks,
Kevin
Thanks,
Kevin
23 Jan 2010 10:45 #1599
by acemi
Replied by acemi on topic Re:Using EMC2 with Motion Controller Card for CNC
You can use a standart parallel port or a supported interface card. This is the list of the supported hardware:
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?EMC2_Supported_Hardware
And there is more info for Mesa cards and for Pico Systems boards in:
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Mesa_Cards
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?PWM_Controller
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?PPMC_Board_Set
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Uni...l_Stepper_Controller
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?PWM_Servo_Amplifiers
Time to create page: 0.098 seconds
