Who did Atom latency test?
26 Apr 2009 14:52 #167
by dfarrell
Who did Atom latency test? was created by dfarrell
One thing that might be nice to add to the "Hardware that works" list is who did the test.
I am a little surprised that the Atom 330 2x 1.6Ghz is indicating so low jitter. It would
be nice if such an inexpensive architecture would give such good performance. Was
the system loaded for the test? Is xubuntu the difference? If this is all true then the cheap
mini notebooks may make nice controllers.
David.
David.
26 Apr 2009 21:01 #172
by alex_joni
Replied by alex_joni on topic Re:Who did Atom latency test?
dfarrell wrote:
If you refer to the wiki page, then you can make the change yourself.
Just add another column with the tester, and maybe means to contact (irc username, obsfucated email, etc).
Regards,
Alex
PS: wiki.linuxcnc.org/cgi-bin/emcinfo.pl?BasicSteps <- how to edit the wiki
David.
Regards,
Alex
- skunkworks
- Thank you received: 148
27 Apr 2009 13:43 #183
by skunkworks
Replied by skunkworks on topic Re:Who did Atom latency test?
Hello - There have been a few people that have tested the atom. It seem to almost push 20us latency but stays under.
imagebin.org/46232
That was with the latest livecd - installed and doing updates. (and glxgears was running)
sam
imagebin.org/46232
sam
Time to create page: 0.121 seconds
