VERY predictable latency... 64 seconds to be exact
09 Feb 2010 20:33 - 09 Feb 2010 20:39 #1845
by joegreen
VERY predictable latency... 64 seconds to be exact was created by joegreen
Over the past few months I have been converting an old CNC router project using TurboCNC to a much more sturdy Bridge Mill with EMC2.
I found an IBM T43 laptop with a built in parallel port that is working great... except for one small issue. Every 64 seconds my latency (as measured by the EMC2 Latency checking program) jumps from ~7500 to ~68,000. If I happen to be jogging an axis or two when that 64 second latency spike hits the axis stalls.
I have turned off every thing that I can think of in the BIOS just to see if it influenced the 64 second time interval but to no avail..
Any Ideas?
Any Ideas?
Last edit: 09 Feb 2010 20:39 by joegreen.
09 Feb 2010 20:53 #1846
by acemi
Replied by acemi on topic Re:VERY predictable latency... 64 seconds to be exact
09 Feb 2010 21:17 #1849
by joegreen
Replied by joegreen on topic Re:VERY predictable latency... 64 seconds to be exact
Thanks Acemi.. I'll try that tonight..
09 Feb 2010 21:34 #1850
by alex_joni
Replied by alex_joni on topic Re:VERY predictable latency... 64 seconds to be exact
09 Feb 2010 21:53 #1851
by joegreen
Can anyone offer any insight on the overheating issue?
Will my internal fan be disabled? Or just never come on?
Should I force air through the system externally ? Or just not worry about it?
10 Feb 2010 11:06 #1854
by alex_joni
Usually it works with the fan stuck at high speeds.
I used a PC with SMI off without issues for a longer period of time, but there's no guarantee that your will too..
You have to try it for a while, then at least reboot and check the temperature in BIOS.
Most BIOS'es have an option to set a max temperature and shutdown the PC to prevent damage.
Regards,
Alex
Regards,
Alex
10 Feb 2010 17:39 #1857
by joegreen
Success!!
Latency never exceeded ~15,000 after an hour.
The fan seems to be running as normal. Not too fast.. not too slow. Just a moderate warm breeze wisping out of the heat exchanger.
Thanks for your help!
