Arduino based USB Pendant for Linuxcnc
28 Jul 2012 16:06 - 16 Aug 2013 17:35 #22562
by ArcEye
Hi
I bought a couple of arduino boards some while back, originally intending to use one of them for I/O within a machine.
That didn't happen, I solved it another way, but the idea of using one within an intelligent pendant took shape.
Someone else published something on the net about the same, but nothing that went beyond making lights flash was actually released.
This was accompanied by much grumbling about obfustication in Jeff Eplers arduino sample programs; since Jeff was squeezing everything into a couple of bytes using bitwise operators, it probably wasn't very easy to understand.
As I program in C / C++ not python, I just started from scratch.
The arduino has very good and easy to use, high level serial libraries.
It made sense to communicate with it by serial over USB, which meant the linking Linuxcnc module would have to be a userspace one.
This means the module runs in userspace rather than on a real time thread.
serialcon.comp
A userspace component can still create hal pins to connect with other parts of Linuxcnc, it will just be slower, but can use all the standard libraries for port access etc.
The first requirement for a component module is that it is launched from Linuxcnc and linked to the running system. Mine has HAL pins which connect to existing axis pins to fetch the current relative position of each axis.
It transmits these readings in fixed size charactor string packets to the arduino. This approach was chosen because the arduino then needs to display the readings onto a LCD screen and update approx every 1/4 of a second. It can display a string immediately without any extra processing, quite important with such a low powered processor.
The output side of the pendant takes the form of a 16 key membrane keypad. I made a printed self adhesive mask for it, to change the key designations. The arduino transmits a single charactor code for each key pressed to the serialcon module.
This is processed and translated in the serialcon module, for the main part into system calls, using the halui interface to Linuxcnc.
halui is a very powerful interface, giving access to most of the commands and data necessary to run a GUI.
From the pendant I can set and reset ESTOP, Machine On, Home All, Mist on / off, select axes, select Jog rates, Jog all axes.
It also operates 3 pre-defined MDI commands.
These could be very powerful commands, running entire programs if so desired.
Mine are currently set to simple movement co-ordinates; MDI 1 commands G28, MDI 2 commands G0 X20 Y20 Z20 and MDI 3 another set of test moves.
The Arduino sketch
The arduino sketch first sets up everything we need, which basically is Serial, Keypad and LCD
I used an i2c backpack on the LCD display which allows everything to be done through 2 wires.
You might not need to do this, the keypad takes up 8 inputs and you could redefine some others
But I had one so I used it.
The main loop listens to the serial port and waits for 9 or more bytes, since that is the packet size
The normal packet consists of the axis letter in upper case and a 8 place float value in a string.
As explained previously this enables the arduino to just write the string to the LCD.
The extra code size and time taken to format to a string from a real float number outweighed any extra time spent sending or receiving the packet.
Things can be kept very simple if you stick to strings over the arduino Serial.
After each check for a serial packet a check is made for keypad inputs
If found they are processed and sent as a single charactor command back to the serialcon component.
Limitations of the Arduino
I did create many more pins and try to display much more system data originally, but found that the poor little arduino just could not cope.
My priority was axis position display as near to real-time as possible, coupled with the swift re-action to keypad commands.
I found that 1/4 second usleep() pauses in the main LinuxCNC component loop, gave the best performance in terms of steady display updating. Any faster and the arduino could not keep up.
If more data was transmitted, the arduino spent too long processing it and keystrokes went unsent.
I am still working upon a reliable method of only sending data if it differs from the previous packet, thus cutting down needless refreshes, without spending the same amount of time doing the checks.
The whole thing is 'work in progress' to an extent, it may take a while to get it exactly as I want, but it works and shows what can be done
What precisely you do, especially with the keypad commands, is entirely down to you
Enjoy if of use
PS. Remove the spurious ? symbols in the code. It seems to be something added by forum software when I cut and pasted into the post
If you enter something that looks like a HTML markup, it sometimes auto completes it or changes it.
In this case it was the % sign, but & or # might trigger it too in the right context
Code attached here
Arduino based USB Pendant for Linuxcnc was created by ArcEye
Hi
serialcon.comp
serialcon.comp
Serial communications with a userspace component
component serialcon "This component services the arduino pendant";
pin in float xposition "Receives current position from Xpos";
pin in float yposition "Receives current position from Ypos";
pin in float zposition "Receives current position from Zpos";
option singleton yes; // makes no sense to have more than one of these components running
option userspace yes;
author "ArcEye";
license "GPL";
#include <stdio.h> /* Standard input/output definitions */
#include <stdlib.h>
#include <stdint.h> /* Standard types */
#include <string.h> /* String function definitions */
#include <unistd.h> /* UNIX standard function definitions */
#include <fcntl.h> /* File control definitions */
#include <errno.h> /* Error number definitions */
#include <termios.h> /* POSIX terminal control definitions */
#include <sys/ioctl.h>
#define BAUDRATE B9600
#define DEVICE "/dev/ttyUSB0"
#define _POSIX_SOURCE 1 /* POSIX compliant source */
// predefs of later functions
void sendCommand(char);
int serialport_init();
struct termios toptions;; // port setup
void user_mainloop(void)
char buffer[50];
char oldbuffer[50];
char ch;
int fd = serialport_init();
// bzero(oldbuffer, 50);
while(fd != -1)
// approx 1/4 sec appears to be optimum period for a steady display with min lag
// may differ on another system with different thread speeds
usleep(250000);
// IT DOESN'T MATTER IF THERE ARE NO OTHER INSTANCES ie SINGLETON, MUST USE THIS MACRO
// In this case, if you don't, no data gets written
FOR_ALL_INSTS()
// %08.03f = 8 digit including decimal point and sign, leading zeros & 3 digit precision with trailing zeros
bzero(buffer, 50);
sprintf(buffer, "X%08.03fY%08.03fZ%08.03f", xposition, yposition, zposition );
// if(strcmp(oldbuffer, buffer) != 0)
write(fd, buffer, sizeof(buffer));
// strcpy(oldbuffer, buffer);
if(read(fd,&ch,1) == 1) // if command byte read from arduino
sendCommand(ch);
close(fd);
exit(0);
int fd;
fd = open(DEVICE, O_RDWR | O_NOCTTY | O_NDELAY);
if (fd == -1)
perror("init_serialport: Unable to open port ");
return -1;
if (tcgetattr(fd, &toptions) < 0)
perror("init_serialport: Couldn't get term attributes");
return -1;
speed_t brate = BAUDRATE;
cfsetispeed(&toptions, brate);
cfsetospeed(&toptions, brate);
// 8N1
toptions.c_cflag &= ~PARENB;
toptions.c_cflag &= ~CSTOPB;
toptions.c_cflag &= ~CSIZE;
toptions.c_cflag |= CS8;
// no flow control
toptions.c_cflag &= ~CRTSCTS;
toptions.c_cflag |= CREAD | CLOCAL; // turn on READ & ignore ctrl lines
toptions.c_iflag &= ~(IXON | IXOFF | IXANY); // turn off s/w flow ctrl
toptions.c_lflag &= ~(ICANON | ECHO | ECHOE | ISIG); // make raw
toptions.c_oflag &= ~OPOST; // make raw
// see: http://unixwiz.net/techtips/termios-vmin-vtime.html
toptions.c_cc[VMIN] = 0;
toptions.c_cc[VTIME] = 20;
if( tcsetattr(fd, TCSANOW, &toptions) < 0)
perror("init_serialport: Couldn't set term attributes");
return -1;
return fd;
// want these 2 to persist between calls
char selected_axis = '0';
int bJogging = false;
void sendCommand(char ch)
char cmdbuff[50];
switch(ch)
case 'X':
break;
case 'Y':
selected_axis = '1';
break;
case 'Z':
selected_axis = '2';
break;
case 'E':
system("halcmd setp halui.estop.activate 1");
system("halcmd setp halui.estop.reset 0");
break;
case 'e':
system("halcmd setp halui.estop.reset 1");
system("halcmd setp halui.estop.activate 0");
break;
case 'M':
system("halcmd setp halui.machine.on 1");
system("halcmd setp halui.machine.off 0");
break;
case 'm':
system("halcmd setp halui.machine.off 1");
system("halcmd setp halui.machine.on 0");
break;
case 'H':
system("halcmd setp halui.home-all 1");
break;
case 'C':
system("halcmd setp halui.mist.on 1");
system("halcmd setp halui.mist.off 0");
break;
case 'c':
system("halcmd setp halui.mist.off 1");
system("halcmd setp halui.mist.on 0");
break;
case '1':
system("halcmd setp halui.mdi-command-10 1");
system("halcmd setp halui.mdi-command-11 0");
system("halcmd setp halui.mdi-command-12 0");
break;
case '2':
system("halcmd setp halui.mdi-command-10 0");
system("halcmd setp halui.mdi-command-11 1");
break;
case '3':
system("halcmd setp halui.mdi-command-12 1");
break;
case '4': // 100mm jog /min
system("halcmd setp halui.jog-speed 100");
break;
case '5': // 10mm jog / min
system("halcmd setp halui.jog-speed 10");
break;
case '6': // 1mm jog / min
system("halcmd setp halui.jog-speed 1");
break;
case 'J':
bJogging = true;
break;
case 'j':
bJogging = false;
sprintf(cmdbuff, "halcmd setp halui.jog.%c.minus 0?", selected_axis );
system(cmdbuff);
sprintf(cmdbuff, "halcmd setp halui.jog.%c.plus 0?", selected_axis );
system(cmdbuff);
break;
case '<':
if(bJogging)
sprintf(cmdbuff, "halcmd setp halui.jog.%c.minus 1?", selected_axis );
system(cmdbuff);
bzero(cmdbuff, sizeof(cmdbuff));
break;
case '>':
if(bJogging)
sprintf(cmdbuff, "halcmd setp halui.jog.%c.plus 1?", selected_axis );
system(cmdbuff);
break;
default:
break;
The Arduino sketch
#include <SoftwareSerial.h>
#include <Key.h>
#include <Keypad.h>
#include "Wire.h"
#include "LiquidCrystal.h"
// predef
// Here we define how the keypad is laid out
char padKeys[4][4] = { {'1','2','3','A'}, {'4','5','6','B'}, {'7','8','9','C'}, {'*','0','#','D'} };
byte rowPins[4] = {5, 4, 3, 2}; // The Arduino pins to connect to the row pins of the keypad
byte colPins[4] = {9, 8, 7, 6}; // The Arduino pins to connect to the column pins of the keypad
Keypad ourKeypad = Keypad( makeKeymap(padKeys), rowPins, colPins, 4, 4); // Set up an instance of the keypad
The circuit: using i2c backpack
* 5V to Arduino 5V pin
* GND to Arduino GND pin
* CLK to Analog #5
* DAT to Analog #4
// Connect via i2c, default address #0 (A0-A2 not jumpered)
LiquidCrystal lcd(0);
char XReading[9]; // 0000.000? pos
char YReading[9];
char ZReading[9];
bool bEstop = true;
bool bMist = false;
bool bJog = false;
bool bMachine = false;
void zeroX() { for(int x = 0; x < 9; x++) XReading[x] = 0;}
void zeroY() { for(int x = 0; x < 9; x++) YReading[x] = 0;}
void zeroZ() { for(int x = 0; x < 9; x++) ZReading[x] = 0;}
void setup()
// start serial port at 9600 bps:
Serial.begin(9600);
// initialize the digital pin as an output.
// Pin 13 has an LED connected on most Arduino boards:
// pinMode(13, OUTPUT);
// set up the LCD's number of rows and columns:
lcd.begin(20, 4);
// Print a message to the LCD.bool bMachine = false;
lcd.setBacklight(HIGH);
lcd.noAutoscroll();
// set the initial field identifiers
lcd.setCursor(0, 0);
lcd.print("X*");
lcd.setCursor(0, 1);
lcd.print("Y ");
lcd.setCursor(0, 2);
lcd.print("Z ");
zeroX();
zeroY();
zeroZ();
void loop()
int x;
char ch, ky;
if(Serial.available() >= 9)
ch = Serial.read();
switch(ch)
case 'X':
while(Serial.available() < 8)
delay(10);
for(x = 0; x < 8; x++)
XReading[x] = Serial.read();
lcd.print("X");
lcd.setCursor(2, 0);
lcd.print(XReading);
zeroX();
break;
case 'Y':
delay(10);
YReading[x] = Serial.read();
lcd.print("Y");
lcd.setCursor(2, 1);
lcd.print(YReading);
zeroY();
break;
case 'Z':
delay(10);
ZReading[x] = Serial.read();
lcd.print("Z");
lcd.setCursor(2, 2);
lcd.print(ZReading);
zeroZ();
break;
default:
break;
if((ky = ourKeypad.getKey()) != NO_KEY )
sendCommand(ky);
void sendCommand(char keyPress)
switch(keyPress)
case 'D': // ESTOP
if(bEstop)
// send estop reset
Serial.write('e');
lcd.setCursor(15, 0);
lcd.print(" ");
bMachine = false;
bEstop = false;
else
// send estop activate & switch machine off too
Serial.write('E');
lcd.print("ESTOP");
bEstop = true;
sendCommand('P'); // M OFF
sendCommand('Q'); // blank MDI display
sendCommand('R'); // JOG OFF
sendCommand('S'); // MIST OFF
break;
case '9': // MACHINE ON / OFF
if(bMachine)
// send machine off
Serial.write('m');
else
// send machine on unless in estop
if(!bEstop)
Serial.write('M');
lcd.setCursor(15, 1);
lcd.print("M ON ");
bMachine = true;
break;
case '7': // HOME ALL
if(!bEstop)
lcd.setCursor(16, 3);
lcd.print(" ");
bMist = false;
Serial.write('H');
break;
case '*': // MDI 1
if(!bEstop && bMachine)
Serial.write('1');
lcd.setCursor(15, 2);
lcd.print("MDI 1");
break;
case '0': // MDI 2
Serial.write('2');
lcd.print("MDI 2");
break;
case '#': // MDI 3
Serial.write('3');
lcd.print("MDI 3");
break;
// re-entrant cases to carry out blanking etc
// to save duplicating code
case 'P': // machine off
lcd.print("M OFF");
bMachine = false;
break;
case 'Q': // MDI off for use by estop etc
lcd.setCursor(15, 2); // blank MDI display
lcd.print(" ");
break;
case 'R': // JOG OFF
lcd.setCursor(0, 3);
lcd.print("JOG OFF");
bJog = false;
break;
case 'S': // MIST OFF
lcd.print(" ");
bMist = false;
break;
case '8': // Mist On / OFF
if(bMist)
// send mist off
Serial.write('c');
sendCommand('S');
else
// send mist activate
Serial.write('C');
lcd.print("MIST");
bMist = true;
break;
case 'A': // X
Serial.write('X');
lcd.setCursor(1, 0);
lcd.print("*");
lcd.setCursor(1, 1);
lcd.print(" ");
lcd.setCursor(1, 2);
lcd.print(" ");
break;
case 'B': // Y
Serial.write('Y');
lcd.print(" ");
lcd.print("*");
lcd.print(" ");
break;
case 'C': // Z
Serial.write('Z');
lcd.print(" ");
lcd.print(" ");
lcd.print("*");
break;
case '2': // JOG ON /OFF
if(bJog)
// send jog off
Serial.write('j');
else
// send jog activate
Serial.write('J');
lcd.print("JOG ON ");
bJog = true;
break;
case '4': // 100mm/min
Serial.write('4');
lcd.setCursor(8, 3);
lcd.print("VEL 100");
break;
case '5': // 10mm/min
Serial.write('5');
lcd.print("VEL 010");
break;
case '6': // 1mm/min
Serial.write('6');
lcd.print("VEL 001");
break;
case '1': // Jog minus <
if(bJog)
Serial.write('<');
break;
case '3': // Jog plus >
if(bJog)
Serial.write('>');
break;
default:
break;
Enjoy if of use
Code attached here
Last edit: 16 Aug 2013 17:35 by ArcEye.
The following user(s) said Thank You: Dorro1971
28 Jul 2012 16:12 - 16 Aug 2013 15:28 #22563
by ArcEye
Replied by ArcEye on topic Re:Arduino based USB Pendant for Linuxcnc
Last edit: 16 Aug 2013 15:28 by ArcEye.
The following user(s) said Thank You: Tchefter
28 Jul 2012 17:04 #22564
by cncbasher
Replied by cncbasher on topic Re:Arduino based USB Pendant for Linuxcnc
great ! time to grab my arduino's
29 Jul 2012 06:48 #22579
by ArcEye
To answer a query re arduino code
I am using the arduino-1.01 code
I use the Adafruit LiquidCrystal library as per here www.adafruit.com/blog/2009/07/10/arduino...quidcrystal-library/
I can't remember where I got the keypad library, it was a link on the suppliers site, so it is attached below.
29 Jul 2012 14:21 #22586
by Rick G
Replied by Rick G on topic Re:Arduino based USB Pendant for Linuxcnc
That is pretty neat. Might just have to give it a try this winter.
I have been using a joypad control to issue mdi commands, but I really like the idea of the display, especially on larger machines where you may be a bit too far from the main monitor.
Rick G
Rick G
01 Aug 2012 12:01 - 01 Aug 2012 12:02 #22654
by ArcEye
A brief addendum
The initiation and pin connections in my hal file look like this
loadusr -W serialcon
# the -W switch is important or the pins might not have been created by time hal tries to connect to them
# as belt and braces I put the initiation command at the top of the file and the below at the end
net Xposition halui.axis.0.pos-relative serialcon.xposition
net Yposition halui.axis.1.pos-relative serialcon.yposition
net Zposition halui.axis.2.pos-relative serialcon.zposition
Whilst I mentioned connecting to Xpos, Ypos and Zpos, this actually gives the machine position, but what you may want is the relative position in work co-ordinates.
I have 2 possible configs depending upon whether I want to use it for initial homing and touch off or thereafter.
As Rick suggested, the LCD axis display was important because I cannot see the VDU display when right next to the mill table on my small mill, as I share the display on the large mills controller head.
Last edit: 01 Aug 2012 12:02 by ArcEye.
10 Aug 2012 14:03 #23022
by JR1050
Replied by JR1050 on topic USB Pendant for Linuxcnc
Arceye,
I love this!! Very cool.Im tring to get a Pokeys or Ipac to function as a simple i/o board,Im running into a problem in as much as the device puts out an actual keyboard character,several of which are Emc hot keys.After looking at your above code,it seeems as though it would be possible to write a comp to address either of these boards.You are obviously very good at this,can you give me some pointers as to where to start?Thanks.
10 Aug 2012 15:25 - 11 Aug 2012 07:08 #23027
by ArcEye
From what I can see of the PoKeys device (and iPac), it emulates keyboard and joystick and is a plug-in USB HID device.
This means it is writing directly to the keyboard buffer (well , generating keyboard events which go to the app with focus) and sending pointer events etc.
That is not quite the same as the arduino with keypad, because it is communicating by serial port (albeit over USB) to a receiving program which is interpreting the packets and taking requested actions.
You will have to tell me what you are trying to do exactly and what you have tried thus far.
Have you looked at attaching it in the same way as you would a game-pad using hal_input?
Might be an altogether simpler method
wiki.linuxcnc.org/cgi-bin/wiki.pl?Simple_Remote_Pendant
and Rick has added all sorts recently
www.linuxcnc.org/index.php/english/compo...id=47&id=22895#22947
Replied by ArcEye on topic Re:USB Pendant for Linuxcnc
Flattery is always a good place to start!You are obviously very good at this,can you give me some pointers as to where to start?
Last edit: 11 Aug 2012 07:08 by ArcEye.
- dangercraft
10 Aug 2012 17:53 #23035
by dangercraft
Replied by dangercraft on topic Re:USB Pendant for Linuxcnc
Arceye,
That is one nahhh-is setup.
I just have one question...
Where did you get the enclosure?
Frank
Frank
10 Aug 2012 18:50 #23038
by JR1050
Replied by JR1050 on topic Re:Arduino based USB Pendant for Linuxcnc
Well,lets just say I call ducks ,ducks....getting a hand held pendent to do all that is impressive.
Anyway,my goal is to build more traditional pendent with common switches and knobs,similar to my Fadal or Yasnac.Presently on the Hardinge Im using gpio with a 5i20 and opto 22 racks for my limited pendent.Opto 22 is an overkill for operator buttons,takes up a bunch of valuable cabinent space and is pricey.I was thinking if i had a 32 input terminal board that acted similar to gpio pins,but via usb,a pendent would be a snap.I could write a pendent comp and be done.
I started with a pokeys and hal input.I couldnt get it to work at all.I then went to the Ipac2 with hal input,which shows the state of the changing inputs,Problem is the Ipac puts out actual keys,which are Emc hot keys.In addition,it also has all these wonky hal pin names and even after reprogramming the thing,several of the pins dont work and the hal names dont always follow the physical pin they should.
I suppose I could open the Axis python file and remark out the hot keys,but this is a rigged temporary fix.Sooo,thats why Im here.By trade Im a toolmaker.not a c++ programmer,not that I havent learned and I am interested,but this is a lot.Sometimes its easier to ask the person who invented the wheel about it, rather then reinventing it!!
Any suggestions??Thanks ahead of time!!
Time to create page: 0.332 seconds
