Linuxcnc with Touchscreen
10 Nov 2012 00:30 #26414
by REEEN
Linuxcnc with Touchscreen was created by REEEN
Hello,
Iam currently Retrofitting a CNC Machine with Linuxcnc for a customer.
This is the first time I use a Touchscreen and suddenly the first problems occured....
I got a Iyama Touchscreen, but against my hopes there's no Plug and Play.... and I have to solve the problem soon because otherwise I have to send it back.
I found this thread :
But I had the same problem as in the third post, make fales...
Does somebody know the cause of the problem ? And what's more important is there a solution ?
Which Touchscreens do you use and what did you have to do to make them work ?
Please reply
Thank you for your help !!
Greets REEEN
Please reply
Greets REEEN
10 Nov 2012 08:29 #26424
by BigJohnT
Replied by BigJohnT on topic Linuxcnc with Touchscreen
Can you describe your problem?
I used an ELO touch screen and other than manually setting the scale and offset for the touch it worked out of the box.
10 Nov 2012 21:19 #26433
by REEEN
Replied by REEEN on topic Linuxcnc with Touchscreen
The Screen displays everything but the touch input is not working nothing happens.
I saw this thread on the net that I posted above.
This thread shows how to install the drivers for the touchscreen but i can't install it.
Look at the link I posted the same thing happens as you can see in the 3 post from the link...
I hope you understand everything now
Sorry for my bad englisch skills...
Mfg REEEN
Mfg REEEN
10 Nov 2012 22:53 #26435
by BigJohnT
There is no link in the post.
Is it a usb or serial touch screen? I assume you plugged the touch interface in to the usb or serial port...
11 Nov 2012 01:47 #26437
by REEEN
11 Nov 2012 01:56 - 11 Nov 2012 22:41 #26438
by BigJohnT
Looks like the patch is for a later version of Ubuntu than LinuxCNC uses.
Re: Driver touch screen t2250mts IIYAMA Quanta
I couldn't get this to work in 10.04 or 10.11 .
Last edit: 11 Nov 2012 22:41 by BigJohnT.
11 Nov 2012 02:05 #26439
by REEEN
On the page linked to the manual where you can get the patch from a several patches, maybe another one fits my needs?
Do you know which is the right one?
11 Nov 2012 22:42 #26457
by BigJohnT
Sorry but I don't know if a patch exists, but look for one for 10.04.
11 Nov 2012 23:28 - 11 Nov 2012 23:29 #26458
by ArcEye
Replied by ArcEye on topic Linuxcnc with Touchscreen
Version 10.05.23 was tested with Ubuntu 10.04 LTS and kernel 2.6.32-xxx so that is the one you want.
sourceforge.net/projects/hidtouchsuite/files/latest/download
Last edit: 11 Nov 2012 23:29 by ArcEye.
13 Nov 2012 17:06 #26524
by REEEN
Thank you!
I already tried it with this one but I couldn't find the right patch for this...
Do you know whrre I can get it from?
Time to create page: 0.196 seconds
