5i25 in PCI-E Adapter Card?
04 Sep 2014 04:57 #50712 by phidauex
Hi, I'm gathering up some spare parts for a revised LinuxCNC computer build, based on a Celeron G540 and the Asrock H71M-DG3 motherboard (Intel H61 chipset) which I have lying around from a cheap used purchase. The main issue at the moment is that my 5i25 IO card is a PCI card, and this motherboard only has a PCI-E slot. Will an adapter card work (link below)? It appears that it will physically fit in my case, using the low profile adapter, but I don't know if it will work with LinuxCNC and the 5i25.
www.amazon.com/StarTech-com-Express-Adap...X1PCI1/dp/B0024CV3SA
Should I scrap the mobo and go for something with a native PCI slot? Or buy a 6i25 which is natively PCI-E instead?
Thanks - Sam
04 Sep 2014 05:32 #50719 by PCW
Replied by PCW on topic 5i25 in PCI-E Adapter Card?
Its very likely to work, but not sure about the mechanics...
04 Sep 2014 07:02 #50725 by andypugh
If you think that you might find a future use for the 5i25, then the 6i25 isn't all that expensive in the grand scheme of things.
05 Sep 2014 01:10 #50782 by phidauex
Both good points. I don't think I'll have a specific use for the 5i25 in the future, so maybe I'll try the adapter first and see if that works.
Thanks - Sam
22 Dec 2015 04:04 #67228 by kstroda
Replied by kstroda on topic 5i25 in PCI-E Adapter Card?
I'm curious to know how the adapter worked out for you?
22 Dec 2015 07:42 #67230 by ArcEye
Replied by ArcEye on topic 5i25 in PCI-E Adapter Card?
I have one of these to use my 5i25 from an old P4 on a mini ITX board.
It works perfectly, I just had to make a new bracket to mount it plus the 5i25, so that the D25 socket could be accessed properly.
If you can wait 3 weeks for delivery, buy one from ebay direct from China.
They are 1/10th the price for the same item as some domestic stockists, who bought them at that price or less themselves
Time to create page: 0.082 seconds
