What is the best Linux CNC PC?
20 Dec 2015 15:25 #67171
by Jake
What is the best Linux CNC PC? was created by Jake
I am still having issues getting my latency down.
If you were to go buy a new machine right now what would it be?
Motherboard, processor, video card?
I keep seeing that the LCNC will only use one core of the processor, is there an "industrial" setup that is barebones fast for the process without the frills ?
20 Dec 2015 16:11 #67173
Replied by PCW on topic What is the best Linux CNC PC?
It depends on whether you expect to do software step generation or not
almost any relatively current PC would be OK if its just running a 1 KHz servo thread
21 Dec 2015 12:52 #67201
I don't think that that has been true for several years.
Anything put on the Wiki will tend to stay there indefinitely, even if it stopped being correct a long time ago.
I recently bought a Jetway JNF9C-2800 which seems to work OK for me, though does actually pop up the occasional real-time delay message, but I am using Mesa cards and servos so it isn't as critical as it might be otherwise.
I have a strong preference for motherboards that take a single 12V power input, and so if I was buying today I would probably look at:
www.mini-box.com/Jetway-JNF9HQL-525-Cedarview which is very low-profile and 12V power.
But, I stress, I know _nothing_ about how that machine performs in a latency test, so this isn't to be taken as a recommendation.
Replied by andypugh on topic What is the best Linux CNC PC?
I keep seeing that the LCNC will only use one core of the processor,?
21 Dec 2015 13:25 #67202
by Jake
Replied by Jake on topic What is the best Linux CNC PC?
Thanks Andy! Ill be working on it this weekend.
Time to create page: 0.092 seconds
