2015/2016 Hardware that works...
28 Dec 2015 20:59 #67410
by tperry
2015/2016 Hardware that works... was created by tperry
I am looking for suggestions on Hardware that work for Software Stepping that I can still buy today. I have a HP Pavillion with a Radeon 6400 video card, Intel I7 that I have unsuccessfully be able to get the mak jitter to below 67500, so I am looking at going out and buying a new motherboard, video, HD, etc.
If you have something that you have built in the last 6 months or so that gives great results please let me know what the magic combination is.
Thanks in advance,
Tim
Thanks in advance,
Tim
- Thank you received: 1369
28 Dec 2015 21:50 #67417
Replied by Todd Zuercher on topic 2015/2016 Hardware that works...
I have not had good luck with the few HP computers I've tried. Most generic motherboards I've used worked well. Unfortunately the last board I've gotten (that works well) doesn't seem to be available now (an Asrock Q1900M-Pro3). But other similar boards are available, and probably work well, (but not guaranteed).
28 Dec 2015 22:17 #67420
Replied by PCW on topic 2015/2016 Hardware that works...
For low end fanless hardware the J800,J1900s seem to be pretty good
For higher end machines the H81 and H97 MBs are good:
for example:
www.newegg.com/Product/Product.aspx?Item=N82E16813157511
freeby.mesanet.com/g3258-rtai.png
Is a low cost Haswell CPU (G3258) in the above MB with about a half day of browser/flash videos/glxgears/etc
for example:
28 Dec 2015 23:06 #67422
Somebody is selling small format PCs on eBay with LinuxCNC pre-installed. I found them by accident.
I don't endorse or recommend them, I am merely saying that they exist:
www.ebay.co.uk/itm/321829401580
Argualby a bit more CPU than the Atom offers is nice, though I have used Atom boards in my machines with no complaints.
Replied by andypugh on topic 2015/2016 Hardware that works...
28 Dec 2015 23:32 - 28 Dec 2015 23:39 #67423
by tperry
Replied by tperry on topic 2015/2016 Hardware that works...
PCW, Are you using the onboard video or another video card?
Last edit: 28 Dec 2015 23:39 by tperry.
28 Dec 2015 23:40 - 28 Dec 2015 23:42 #67424
onboard (well its internal to the G3258 CPU)
Last edit: 28 Dec 2015 23:42 by PCW.
The following user(s) said Thank You: tperry
29 Dec 2015 20:56 #67462
by tperry
I have ordered the H97 board, processor, etc, will see how it all works out, in the mean time I am still playing trying to get the latency down on the HP, going bleeding edge with Jessie just for something to do while I wait for the post office.
Thanks for the suggestions,
Tim
Tim
30 Dec 2015 10:01 #67500
by ArcEye
Just be aware of this thread and others, the GMA video chip can be a real pain in these, especially with 2.6.x kernels
forum.linuxcnc.org/forum/18-computer/270...roblems?limitstart=0
(I am suspicious of the alleged latency screenshot in the ebay entry, because the config picker is also open and no sign of any glxgears etc to actually load the system.)
Replied by ArcEye on topic 2015/2016 Hardware that works...
31 Dec 2015 02:20 #67577
by SrLange61
Replied by SrLange61 on topic 2015/2016 Hardware that works...
This year I upgraded to a G3258 and over-clocked it to 4000. No other m/b settings were changed. For the 64bit rt-preemp kernel I got better latency with a old 450gts Nvidia card.
srl
srl
07 Jan 2016 16:45 #68023
by tperry
So I went with PCW's recomendation and put in aASRock H97 Pro4 with an Intel G3258 CPU, 8GB Memory ( perhaps one day I will run 64bit ).
Additionally I put in 2 StarTech PCIE parallel ports and an Intel PCI Wireless N RNX-N250PC2 card.
Initial performance was dismal. Over 1 second delays, so I started pulling out hardware that was not essential, the network card. Immediately I am getting stable Max jitter of 3602 Servo & 4012 on the Base. So I really wanted this on the network so I threw on a bridge I have to the onboard network port ( after downloading and compiling the driver from intel as the Wheezy drivers did not work ( downloadcenter.intel.com/product/71305/I...et-Connection-I218-V ) and viola still stable within 10-30ns of the pervious test. I found another alternative to removing the Wireless networkcard is just to disable wireless networking in the network control panel and everything will be stable, so you could use it that way, just when running linuxcnc be sure to disable Wireless networking.
This result is with glxgears running, about 85-90% CPU usage, surfing the internet, and downloading over 1GB of data during the test. Pretty good results.
So I feel like I know have a system that is capable of driving my Mill.
Thanks all for the suggestions.
Tim
Tim
Time to create page: 0.136 seconds
