Connetcing to internt via proxy server
18 Jan 2016 09:09 #68659
by sharat
Connetcing to internt via proxy server was created by sharat
What is the method for configuring http proxy in LinuxCnc ? I tried googling issue, but I was not able to configure the http proxy. I have configured the Internet browser "Iceweasel and I am able to connect to Internet but I am not able to install any package.
Note: I am very new to Linux OS.
I would be very grateful to you guys for any kind of help.
Thankyou
Thankyou
18 Jan 2016 12:06 - 18 Jan 2016 12:06 #68671
by ArcEye
Replied by ArcEye on topic Connetcing to internt via proxy server
Linuxcnc is a software package built into a Debian 7 distro, so the question is about Debian not Linuxcnc.
I am not convinced that this what you actually mean
From Iceweasel: Preferences > Advanced > Network > Settings
If you mean how do you set Synaptic to use a proxy for installing packages
From Synaptic: Settings > Preferences > Network
Last edit: 18 Jan 2016 12:06 by ArcEye.
The following user(s) said Thank You: sharat
18 Jan 2016 13:34 #68683
by cncbasher
Replied by cncbasher on topic Connetcing to internt via proxy server
if your unable to install any packages , this is a debian permissions error , you either have your user set incorrectly and not set as root etc to set your username as root do the following .
use sudo gedit /etc/sudoers
if you dont have gedit as an editor you can use vim or any other , you would need to start up as root , this is done using $ su root <password >
find entry in /etc/sudoers or use sudo gedit /etc/sudoers
root ALL=(ALL:ALL) ALL
copy and paste to the next line and replace root with your user name and save and restart
demo ALL=(ALL:ALL) ALL
showing in this case demo as user
18 Jan 2016 15:33 #68688
by sharat
Replied by sharat on topic Connetcing to internt via proxy server
Hi ArcEye,
Thanks for the guidance. I configured the proxy setting in Synaptic: Settings > Preferences > Network and things started getting to installed. .I wonder why the solution given in the following link did not work for me.
pc-freak.net/blog/aptget-proxy-making-de...-proxified-networks/
Once again thank you a lot.
18 Jan 2016 15:42 #68691
by sharat
Hi cncbasher,
Thanks for your help. I could get packages installed on my Debian using the suggestion given by Arceye. What you wrote was very informative for me.
But I wonder why the solution given in the link below did not work for me.
Thanks a lot once again.
18 Jan 2016 17:17 #68697
by ArcEye
We have no idea what you actually did, which proxy service you tried to use etc.
I think the menu based solution is far simpler and no bible quotes
Time to create page: 0.080 seconds
