Running on media the latency is low,on hd is high.
12 Feb 2016 11:52 - 12 Feb 2016 17:14 #70036
by aparecido
Running on media the latency is low,on hd is high. was created by aparecido
If I run Debian 7 + Linuxcnc the cd and leaving open with several things, including mp3 and video, stabilized 17385ns.
But if I run hd ide 40gb, easy passes of 500000ns running the same things and using the same driver (nouveau).
Motherboard ASUS K8V-X SE + Sempron 2600+
2gb ram
Video Geforce 5200
HD40GB IDE
I noticed something else, I made the boot from the hd in recovery mode and the latency is just 14500ns even me doing a lot of things at once, but does not mount more the stick does not work the network / internet.
Any suggestions of what I can do to try to solve?
2gb ram
Video Geforce 5200
HD40GB IDE
Last edit: 12 Feb 2016 17:14 by aparecido.
13 Feb 2016 20:51 #70086
by aparecido
Replied by aparecido on topic Running on media the latency is low,on hd is high.
Found the problem, if you use both motherboard IDE ports, the latency is too high, using the ide dvd drive and HD on the same flat cable, the latency is at most the 15000ns.
15 Feb 2016 08:32 #70154
by Amedee
Replied by Amedee on topic Running on media the latency is low,on hd is high.
Just FYI, I use an ASUS board from about the same era (see
here
), and I replaced the old IDE disk by a cheap SATA SSD.
I disabled the IDE interface in the BIOS (used an USB CD drive for the install) and latency was better after that.
Note that the BIOS is important as well, I upgraded to the latest one and latency was really bad, so I reverted to what I had before (I did not tried all the version though )
15 Feb 2016 11:08 #70156
by aparecido
I understand, in the case here I installed linuxcnc / debian in HD and then hung up the drive CD / DVD and the latency was between 15000 and 17000, as I will not need to use the drive dvd / cd there can let him off. With the release of the old bios or the latest the same thing happens.
Thanks for the answer.
Time to create page: 0.072 seconds
