Installing gedit
21 Feb 2016 17:32 #70447
by ArcEye
Replied by ArcEye on topic Installing gedit
I am confused,
did you try apt-get install gedit AFTER removing the comments in sources.list and running apt-get update?
If you got errors then, cut and paste them and attach.
21 Feb 2016 18:01 #70450
by JohnK43
Replied by JohnK43 on topic Installing gedit
Yup, I did all that,got frustrated and reinstalled the OS.
1. checked that etc/apt/sources.list was not commented out
2. sudo apt-get update
3. sudo apt-get install gedit-common gedit gedit-plugins
process ran exited with no errors or warnings and I now have gedit installed and working.
Now all I have to do is update linuxcnc with the master,
What I did last time is use the LinuxCNC buildbot instructions buildbot.linuxcnc.org
I think that that is where all my troubles started. I maybe put something where it was not supposed to go.????
short version
get a key
get the master stanza into etc/apt/sources.list.d/linuxcnc-buildot.list
sudo apt-get update
sudo apt-get install linuxcnc
any glaring errors to this. Maybe I put stuff in the wrong place. When I did it I uncommented the entry for the master list and commented the other entries.(good or bad)?
Have not done that yet. As i said I did something stuped.
short version
get a key
sudo apt-get update
21 Feb 2016 18:33 #70451
by JohnK43
ArcEye
I updated linuxcnc and everything worked as advertised. I believe all my problems were from me putting stuff in the wrong place.
I do appreciate the time and effort. I should have done this to start with and regret the inconvenience. However I am more knowledgeable
about all this so that is a big plus for me. Thanks again for all the guidance and assistance.
21 Feb 2016 18:39 #70452
by JohnK43
As everything is working could you reccomend another app to install to make sure it works after updating linuxcnc?
22 Feb 2016 07:09 #70469
by ArcEye
synaptic, then you won't have to install packages from the command line
Time to create page: 0.064 seconds
