Touch Screen Recommendations
27 May 2016 12:03 - 27 May 2016 12:04 #75150
by perra_e
Replied by perra_e on topic Touch Screen Recommendations
I have an ELO touch screen that has a very strange behavior. (Don't remember the model right now)
I didn't manage to get it work with anything else then ELO's own drivers for Linux.
With ELO's drivers it works fine, but only for about 20-30 minutes. After that it loses the calibration and the mouse is parked at the bottom of the screen. I don't even have to run any program for this to happen. It can idle and after a while it stops working. If I boot it works fine again for 20-30 minutes. I'm have installed linuxcnc from 2.7.4 iso with uspace added since I use Ethernet.
This is a very odd behavior!
--Per
edit: It is connected via USB.
--Per
Last edit: 27 May 2016 12:04 by perra_e.
30 May 2016 18:38 #75256
by Muzzer
Replied by Muzzer on topic Touch Screen Recommendations
The Asus VT207N is available for £160 or so eg
Visiontech-2000
(link to Amazon UK shopfront). Sounds like a recommended option. Haven't seen anything much below this price.
30 May 2016 19:26 #75258
by Lcvette
Interesting.. So try and stay away from USB it sounds like...hmm will have to research this some more..
Replied by Lcvette on topic Touch Screen Recommendations
--Per
- Wolfpacker
05 Aug 2016 18:04 #78393
by Wolfpacker
Replied by Wolfpacker on topic Touch Screen Recommendations
Per,
The Elo touch screen is most likely Projected Capacitive. They are good panels, but one of the disadvantages of the technology is that they can be susceptible to electromagnetic noise (like the noise generated by motors and fluorescent lights). The behavior you described is consistent with this kind of interference.
Try a simple test: just plug the monitor power cord into an outlet on a different circuit (preferably one without lights or motors ) and see if the behavior improves.
Good luck,
Wolfpacker
Good luck,
Wolfpacker
--Per
11 Aug 2016 11:52 #78604
Replied by andypugh on topic Touch Screen Recommendations
Sorry for the delay in approving this message
16 Aug 2016 21:32 #78908
by kagouraki
Hello, can you tell me if anyone of these would work; it will be a plasma cnc with gmoccapy. Thank you.
www.ebay.de/itm/141768750392
www.ebay.de/itm/131599232058
Replied by kagouraki on topic Touch Screen Recommendations
I have had luck with ELO but it is on Ubuntu 10.04 and only certain types work. I can look up the part numbers if you need them.
JT
- Dale Lusby
31 Aug 2016 06:30 #79765
by Dale Lusby
I found a used PXL2230MW locally for only $60. It was plug and play as well. I am saving the other one for my Mori Seiki lathe retrofit and will be using the 2230 for my mill.
It feels similar to my other Planar although having the raised plastic frame around the edge does make it a bit difficult to touch items near the edge (or maybe it's just my "thick" fingers. I'm more than pleased with it so far.
Replied by Dale Lusby on topic Touch Screen Recommendations
Dale,
I like the looks of that touch screen. What distro are you using? Did you use wheezy the install ISO/Linuxcnc?
I'm looking at purchasing a Planar PXL2230MW. I'm hoping it will be plug and play as well. I do plan on installing Linux mint LMDE 2 so it should have the same support.
08 Nov 2016 14:46 #82590
by freemo716
Replied by freemo716 on topic Touch Screen Recommendations
hi, i am using this model too , but cant figure how to install driver on ubuntu 14.04 , can you help me please ?
- cncnoob1979
- Thank you received: 75
10 Dec 2016 01:57 #83872
by cncnoob1979
Replied by cncnoob1979 on topic Touch Screen Recommendations
What model touch screen do you have? If its the Planar that I have you just have to calibrate it.
- cncnoob1979
15 Dec 2016 00:34 #84131
by cncnoob1979
I just purchased an Asus VT207N. I wanted 16:9 wide-screen resolution for linuxcnc. The planar worked very well and was easy to set-up, I just needed a widescreen.
The Asus VT207N worked very well after issuing the command:
afterwards I had to put this statment into my /etc/rc.local file (before the “exit” statement)
Works very well and was basically plug and play. I purchased it from ebay for 130$USD and new is approx 180$USD.
It works very well and Its a HUGE difference going to wide-screen with linuxcnc than 4:3. If you are looking for a touch screen recommendation then look no further! This one is a winner folks 1600x900 resolution.
sudo modprobe hid_multitouch
modprobe hid-multitouch
The following user(s) said Thank You: tommylight, kagouraki
