Touch Screen Recommendations
- Thank you received: 5925
27 May 2017 23:01 #93728
Replied by tommylight on topic Touch Screen Recommendations
www.ucuzsarf.com/image/data/resimler/hdm...rici-aparat-6001.jpg
I got that ! It can be used as an output from the graphic card DVI to TV HDMI ! Nothing else. I need the other way round.
So you are right, thank you for the tip.
- racedirector
- Thank you received: 41
17 Sep 2018 09:27 #117646
by racedirector
Replied by racedirector on topic Touch Screen Recommendations
Late into this I know but I just installed a Planar PCT2235 and it just works. Using for Pathpilot at the moment. No calibration, USB "powered" but it is cool!
Cheers
Cheers
- Ivan_The_Red
07 Mar 2019 00:20 - 07 Mar 2019 00:22 #127930
by Ivan_The_Red
Replied by Ivan_The_Red on topic Touch Screen Recommendations
Just tried an HP E230T and it worked fine, no calibration required, but only single touch. I also needed to issue the SUDO MODPROBE HID_MULTITOUCH command before it would work. Im currently using the Debian Wheezy version of Linuxcnc.
Last edit: 07 Mar 2019 00:22 by Ivan_The_Red.
Time to create page: 0.131 seconds
