Atheros wireless pcie card
26 Mar 2016 14:04 - 26 Mar 2016 14:15 #72181
by Vinci
Atheros wireless pcie card was created by Vinci
Hello
I'd like to add a pcie wireless card which uses an Atheros chipset to my lab computer. According to linuxwireless.org website the ath9k kernel module is used in this case.
Sadly plug&play didn't work as the ath9k module doesn't get loaded automatically. A simple lspcie confirmed that, the card shows but the module doesn't. Is there a reason for this? Does it interfere with the real-time kernel in any way? If not, can I manually add the module to to load at system startup? And if yes, could somebody please explain me how, since I've never done that before...
/edit
ah ok, adding ath9k to etc/modules did the trick
The thing is, the module still shows as "unused" at the damn card...
/edit
Last edit: 26 Mar 2016 14:15 by Vinci.
26 Mar 2016 15:44 - 26 Mar 2016 16:43 #72185
by ArcEye
Replied by ArcEye on topic Atheros wireless pcie card
Hi
We cannot guess which OS and which kernel you are running, so you will have to tell us.
Also the exact model of the wi-fi card.
There are 15 different atheros chips that I have found.
Next read wiki.debian.org/ath9k
You will note that whilst the ath9k driver is correct for 802.11n PCI/PCI-E chips,
the driver for 802.11a/bg PCI/PCI-E devices is actually the ath5k
Ensure you are loading the correct module and then reboot your computer.
If your card is not working then post the output from
sudo lspci -vv > lspci.txt (the lspci.txt file)
from
dmesg | grep'eth0' 'wlan'
and from
lsmod | grep 'ath'
Hopefully will be able to see what is happening
PS
Also check that firmware-linux-free and firmware-linux-nonfree are installed, plus IMPORTANTLY firmware-atheros
The last one would definitely not be routinely installed.
from
dmesg | grep
and from
lsmod | grep 'ath'
PS
Last edit: 26 Mar 2016 16:43 by ArcEye.
23 Apr 2016 10:22 #73740
by Vinci
Replied by Vinci on topic Atheros wireless pcie card
Sry for the late reply, I only get to work on my machine every other week...
Anyway I just updated to the latest build and all of the sudden everything is working fine.
Time to create page: 0.069 seconds
