Both fast CPU & step generation desktop
02 Jun 2016 21:36 #75365
by tarasko
Both fast CPU & step generation desktop was created by tarasko
I'm looking for a good LinuxCNC desktop candidate, but with powerful CPU. I need also to calculate toolpathes on it too with Blendercam.
Currently I'm using Intel Atom D425 (only 512Kb L2 cache, with 1.8Ghz frequency). Well, for step generation it's a good partner, but It horribly slow as a toolpath calculation machine.
Does anybody found fast CPU destktop for LinuxCNC?
02 Jun 2016 22:23 #75367
by BigJohnT
Replied by BigJohnT on topic Both fast CPU & step generation desktop
I'm real happy with my Gigabyte H81M-S2H GSM mother board. The H81M has < 5000 servo period latency, the best I've ever seen. I used a G3260 processor with the H81M.
JT
JT
The following user(s) said Thank You: tarasko
06 Jun 2016 17:19 #75564
by tarasko
Thanks. There is no any other options yet. So I will choose your hardware option. Thanks for advice!
Replied by tarasko on topic Both fast CPU & step generation desktop
JT
07 Jun 2016 18:21 #75653
by tarasko
I didn't find andy LPT port on Gigabyte H81M-S2H GSM, maybe you meant GA-H81M-S2PH ?
JT
08 Jun 2016 10:40 #75678
by BigJohnT
Nope no mistake, I have no need for a parallel port. My ASRock H97 Pro4 has a LPT header on the motherboard and running RT-Preempt kernel with LinuxCNC Uspace I get 15k latency with 5 GLX Gears running.
JT
JT
I didn't find any LPT port on Gigabyte H81M-S2H GSM, maybe you meant GA-H81M-S2PH ?
JT
13 Jun 2016 22:16 #75938
by tarasko
I've just bought the same hardware you have, but in debian wheezy intel graphics driver is too old for g3260. I can't set resolution higher than 1440x900 ? Did you face the same problem? Thanks.
13 Jun 2016 22:57 #75939
by BigJohnT
No, I'm running LinuxMint with the Mate desktop. I've just installed Debian Sneezy on one computer with no issues but not that one. I could swap hard drives perhaps and see if I have an issue.
gnipsel.com/files/linuxmint/mint17.3.txt
JT
JT
14 Jun 2016 08:48 - 14 Jun 2016 08:51 #75968
by tarasko
Thanks. I'm curious is there way to use x86_64 environment? Because of limitation of max RAM capacity (for i386 max available address space is 2^32 = 4GB). I have 16Gb of RAM and it's useless in i386, besides, generation of CAM toolpathes with Blendercam requires a large amount of RAM. Of course it's possible work having 0.8Gb of RAM but it could be much faster to have access to all 16Gb RAM that I have.
Last edit: 14 Jun 2016 08:51 by tarasko.
14 Jun 2016 21:16 - 14 Jun 2016 21:16 #76026
by tarasko
I've installed Debian Jessie x86_64 with Linux cnc 3.18.13-rt10mah+ #3 SMP PREEMPT RT kernel.
Well latency test is showing ~70000 ns Base thread period comparing to stock i386 Wheezy image with RTAI kernel which gives ~6000 ns. So the main problem is that there are no RTAI kernel for x86_64? Is there a way to compile such? Thanks.
Last edit: 14 Jun 2016 21:16 by tarasko.
15 Jun 2016 15:10 #76090
Replied by andypugh on topic Both fast CPU & step generation desktop
Depending on the hardware 70,000nS might be perfectly OK.
Time to create page: 0.231 seconds
