Wireless USB suggestion
28 Jun 2016 23:11 #76767
by fc60
Wireless USB suggestion was created by fc60
Greetings,
My machine is running LinuxCNC 2.5.4 with Ubuntu 10.01.
I would like to purchase a "plug and play" USB Wireless device for convenient access to my Internet.
With kind regards,
David
With kind regards,
David
29 Jun 2016 13:44 #76787
Replied by PCW on topic Wireless USB suggestion
This one:
Edimax EW 7811UN N150 USB 2 0 Wireless Nano Adapter
is known to work withTormach Pathpilot which is Ubuntu 10.04 based
- eFalegname
- Thank you received: 30
29 Jun 2016 16:20 #76795
by eFalegname
Replied by eFalegname on topic Wireless USB suggestion
You find it
here
for 9€, free worldshipping
29 Jun 2016 17:34 #76798
Oops I have to take it back, looks like Tormach had to install a driver for the Edimax so Ubuntu 10.04 will not support it
"out of the box"
Might be better to either use Ethernet, update the OS or add the driver (the Edimax uses a RTL8192CU)
"out of the box"
29 Jun 2016 18:01 #76799
by fc60
Replied by fc60 on topic Wireless USB suggestion
Greetings,
What a challenge.
I did find a web page that listed the various USB adapters and their chipsets with compatibility. I just made an offer on an SMC device.
I cannot upgrade my machine for reasons that involve a long explanation.
I can, however, connect a 50 foot Ethernet cable and go that route for emergent access. This method works fine as the OS recognizes my internal Ethernet port.
Cheers,
Dave
What a challenge.
Cheers,
Dave
29 Jun 2016 20:19 #76802
Another option is to use a WIFI router as a Ethernet connected access point
29 Jun 2016 21:46 #76807
by fc60
Great suggestion.
Sadly, you would have to see my shop and realize I would not have any room to set it up. I am also running out of electricity. I have to unplug one machine to free up a socket to plug the CNC into.
Ahhh, to be organized. Regrettably, not today.
If/when I do find a working USB stick, I will post my results.
Cheers,
Dave
Cheers,
Dave
30 Jun 2016 01:41 - 30 Jun 2016 01:42 #76816
by CMB
Replied by CMB on topic Wireless USB suggestion
I've had a tough time finding a usb wifi module that doesn't use an RTL 8xxx chipset. However the Edimax EW 7811UN N150 works great if you install the correct driver which I found to be non trivial without the assistance of this guide:
sites.google.com/site/easylinuxtipsproject/reserve-7
One thing to note, in my experience if you simply plug in the edimax and it seems to connect and function, look at the blue led. If it's on steady that's a tell tale sign the wrong driver is installed which will cripple the speed and cause hangups. Once the correct driver is installed all mine have blinked rapidly. I've used a half dozen of them on Wheezy and 2 on Mint with good results.
To achieve max range it seems to like to be installed into a powered hub, a short extension cable or in a usb port that doesn't have too many other items connected to the same internal hub.
Last edit: 30 Jun 2016 01:42 by CMB.
03 Jul 2016 18:40 #76944
by gryphon68
Replied by gryphon68 on topic Wireless USB suggestion
I'm using a D-Link DWL-G122. Was first supported in a 2008 Linux Kernel (2.6.24), Mine is Rev B1. You'd probably have to shop eBay to find one.
The following user(s) said Thank You: fc60
- eFalegname
06 Jul 2016 12:55 #77076
by eFalegname
Thank you very much CMB, now my network has gained a lot in terms of speed....
Time to create page: 0.098 seconds
