Ati Rage XL 8mb PCI video card.
- isladelobos
30 Jul 2016 06:27 #78154
by isladelobos
Ati Rage XL 8mb PCI video card. was created by isladelobos
Hi.
I have this video card but fails with this xserver or drivers.
lspci
05:06.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI Rage XL (rev 27) (prog-if 00 [VGA controller])
The error is ever "out of range" "Frequency not supported" with two different screens.
What is the way to make it work?
Tnx.
lspci
Tnx.
- Thank you received: 5924
30 Jul 2016 11:32 #78159
Replied by tommylight on topic Ati Rage XL 8mb PCI video card.
"out of range" "Frequency not supported" are monitor errors, not graphic card, you need a monitor that can do 48Hz, as it is the default frequency on old graphic cards.
You can also modify the xorg.conf to set the default at 60Hz, but it is hard to do without the monitor actually showing something.
If you are using Ubuntu 10.04, it tends to do that a lot on older hardware, so get wheezy iso and give it a try, chances are it will work.
Regards,
Tom
Regards,
Tom
The following user(s) said Thank You: isladelobos
- isladelobos
31 Jul 2016 12:27 - 31 Jul 2016 12:33 #78181
by isladelobos
Replied by isladelobos on topic Ati Rage XL 8mb PCI video card.
Finally i entered in recovery mode and created a new xorg.conf file in /etc/X11/ with the content:
Section "Device"
Identifier "ATI Technologies, Inc. Rage XL"
Driver "ati"
BusID "PCI:0:7:0"
EndSection
Section "Monitor"
Identifier "Generic Monitor"
HorizSync 22.0 - 82.0
VertRefresh 60.0 - 76.0
EndSection
Section "Screen"
Identifier "Default Screen"
Device "ATI Technologies, Inc. Rage XL"
Monitor "Generic Monitor"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1280x1024" "1152x864" "1024x768" "800x600" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
EndSection
Now is working.
Section "Device"
Driver "ati"
BusID "PCI:0:7:0"
EndSection
Section "Monitor"
EndSection
Section "Screen"
DefaultDepth 24
Depth 1
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
EndSection
Now is working.
Last edit: 31 Jul 2016 12:33 by isladelobos.
- isladelobos
31 Jul 2016 13:10 #78183
by isladelobos
But this card not resolve my latency problems...
Now slower than the internal graphic card. (32mb)
Time to create page: 0.071 seconds
