Is There a Known Good Hardware List?
06 Sep 2016 20:47 #80090
Replied by andypugh on topic Is There a Known Good Hardware List?
I think that it can simplify your thinking to consider the PC as "The LinuxCNC board" and treat it as just another component. It isn't even one of the expensive ones.
I like to bolt a 12V-supplied Mini-ITX board to a base plate then plug in an 8GB DOM SSD module and RAM then run it off system power. Bolt the interface cards to the same backplate and you have a "CNC Module"
The cable on the DOM is a kludge, I snapped off the connector and had to solder on a short length of SATA cable to rescue the situation, I was glad it wasn't IDE or PATA. Or Ultra-Wide SCSI.
- Thank you received: 5922
06 Sep 2016 20:52 #80092
LOL, i still have some of those ultra wide SCSI cables and drives here. Want me to mail you some???
Replied by tommylight on topic Is There a Known Good Hardware List?
06 Sep 2016 21:32 #80093
by Clive S
Replied by Clive S on topic Is There a Known Good Hardware List?
Would you mind telling me if it has pci or pcix on.
06 Sep 2016 21:41 #80094
SCSI What on earth is that ?
Replied by rodw on topic Is There a Known Good Hardware List?
06 Sep 2016 21:54 #80095
pronounced "skazi", it was HDD controller used in servers and workstations, till SATA became the standard.
06 Sep 2016 21:57 #80096
[quote="tommylight" post=80095}
pronounced "skazi", it was HDD controller used in servers and workstations, till SATA became the standard.[/quote]
Ahh yes I remember, some fossil from Adaptec wasn't it?
How could I forget .......
06 Sep 2016 22:09 #80097
LOL
Yup that was it, it was bloody expensive but fast for that time period.
07 Sep 2016 17:04 #80137
Not an Adaptec invention. SCSI was (I have heard) originaly Shugart Computer System Interface
It was used on high-end stuff, and is still used today, though now it is the same command set but serial connection.
[hh yes I remember, some fossil from Adaptec wasn't it? .
07 Sep 2016 17:08 #80138
by Clive S
Does it have a pci or a pcix slotIf you want a stable PC (this year I used it on more than 6 machines):
Motherboard MSI H97M-E35 1
Intel Pentium G3460 3.5GHz 3MB SK1150 (BX80646G3460)
4Gb of RAM
This PC build is quite solid and fast, preforms quite well in linuxcnc.
08 Oct 2016 13:07 - 08 Oct 2016 13:30 #81404
by Clive S
Andy
I have this above but does the DOM require a driver as the linuxcnc iso does not see it a a drive ?
Last edit: 08 Oct 2016 13:30 by Clive S.
Time to create page: 0.097 seconds
