Is There a Known Good Hardware List?
08 Oct 2016 14:47 #81415
That's odd. Is it plugged in to a SATA port? In that case the system shouldn't even know that it isn't a HDD.
Does it show up in the BIOS screen?
Replied by andypugh on topic Is There a Known Good Hardware List?
I have this above but does the DOM require a driver as the linuxcnc iso does not see it a a drive ?
08 Oct 2016 14:51 #81416
by Clive S
Replied by Clive S on topic Is There a Known Good Hardware List?
Thanks for the rapid response Andy.
Yes it is plugged into a SATA port and does have 5V going to it. It does warm up so is getting power.
It is not shown in the bios. Perhaps it is faulty
The board runs fine with another SSD
08 Oct 2016 16:02 #81420
If the BIOS can't see it, then I would suspect a fault.
Assuming that you are managing to boot from USB or similar, is there any sign of it in /dev/ ?
08 Oct 2016 16:50 #81425
by Clive S
Thanks for the info.
I have booted from my SSD and there is no sign of it in /dev So I will try and send it back.If the BIOS can't see it, then I would suspect a fault.
- Thank you received: 5907
08 Oct 2016 23:18 #81439
Replied by tommylight on topic Is There a Known Good Hardware List?
sudo fdisk -l
there it will show all drives even if not formatted or not functional.
If it does not show there, send it back
09 Oct 2016 10:01 #81452
by Clive S
It does not show up with the above so I will have to try and get it replaced. Thankssudo fdisk -l
