General Computer & Hardware Components Required?
- Thank you received: 1369
20 Sep 2016 03:08 #80649
Replied by Todd Zuercher on topic General Computer & Hardware Components Required?
I have a machine running a D2700 (software stepping) with Linuxcnc Ubuntu 10.04. It is working perfectly fine graphically for me. It is only for a cnc machine control, I don't need it to run HD video, so using 1024x768 video resolution is perfectly adequate for my uses (pretty sure the monitor plugged into it isn't capable of anything better.)
The following user(s) said Thank You: gismofx
20 Sep 2016 10:42 #80662
by gismofx
Replied by gismofx on topic General Computer & Hardware Components Required?
Thanks. I knew it usable; not completely incompatible, but for my peace of mind I wanted something fully supported. From what I read, there is no hardware acceleration driver on that PowerVR and it seemed a little trickier to get higher resolutions working. I also read that only the VGA port was usable.
20 Sep 2016 12:34 #80667
I'm not sure if the board I'm using has anything other than a VGA port, but it has been running a Linuxcnc controlled router for nearly 5 years.
20 Sep 2016 17:57 #80682
Replied by andypugh on topic General Computer & Hardware Components Required?
I did force it to work, with a hand-crafted Xorg.conf and note that that discussion is from a few years ago, and driver support might have improved.
20 Sep 2016 23:11 #80697
by gismofx
Yea, that seems like on of the fixes. I searched for a while if there were any new developments on a driver. Seems to have went dead a few years back.
Time to create page: 0.184 seconds
