important notes for latency tweak in modern pc
11 Oct 2016 16:47 #81556
by taloot
important notes for latency tweak in modern pc was created by taloot
i was testing with rt kernel and jessie and i noticed couple of points that have very good effect.
1. dual channel momery
2. momery voltage tweak (very large impact)
3.enable speedstep or turbo
4. enable usb 3.0 (disable it will give 5.0ns more)
5. reduce the memory of the integrated gpu i use 64mb
6. don't disable audio from bios
7. disable KVM
8, disable and enable LPT from bios and try and choose different irq
this is applied to J1900 asrock latency never pass 4.3ns and 3.9ns for servo thread
also i try H110 asus ddr3 +G4400 and result was better than the j1900 just the motherboard dead from short before i finish tweaking
7. disable KVM
The following user(s) said Thank You: aak67
06 Jan 2017 14:43 #85341
by aak67
Replied by aak67 on topic important notes for latency tweak in modern pc
Hi taloot,
thanks a lot . I bought the ASUS H110-Plus (with parallel port) an on board graphic with 2x4GB DDR4 Ram and Intel G4400: it works perfekt for me. With the BIOS defaults (except secure boot) i have a max jitter of 21000
The Intel Pentium G4400, 2x 3.30GHz is without hypertheading, but that's better for linuxcnc
I don't test point 2 7 or 8
29 Dec 2020 07:06 #193405
by aleksamc
Replied by aleksamc on topic important notes for latency tweak in modern pc
I bought Mini PC without fan with Intel J1900 processor on board with 4G RAM.
I disabled memory save in bios and reduced video memory size to 64Mb, but unfortunatly have very big latency (213000). I want to use this PC with 7i95 ethernet board
30 Dec 2020 20:05 #193581
Replied by rodw on topic important notes for latency tweak in modern pc
Try disabling the Cstate or set it to 1.
I had good luck with one of these but cannot get others to work due to issues with the Baytrail chipset and Linux kernel which remain unresolved.
31 Dec 2020 10:13 #193624
by aleksamc
I've disabled everything I could )))
And get result of 30 000 latency. Once only after long time of unsued working it jumped to 300 000 of latency.
I see somebody use histograms for latecy tests but I don't know what that program is.
I think with Mesa ethernet board it will work fine, more over for this task I plan to do. But standart PC's are give much better results.
I bought this PC because it's fanless, it will work in extreme environment, so standart will die very quickly.
- Thank you received: 5920
31 Dec 2020 12:10 #193634
Replied by tommylight on topic important notes for latency tweak in modern pc
In a terminal:
latency-histogram --nobase --sbinsize 1000 --show
Time to create page: 0.101 seconds
