Parallel Port Error - No Such Device
- GingerPhil
03 Jan 2017 23:44 #85177
by GingerPhil
Parallel Port Error - No Such Device was created by GingerPhil
Having a few new problems trying to get LinuxCNC to work!
The parallel port is on the motherboard, yet LinuxCNC can't seem to detect it.
I now get the error: (regardless of if parport_pc, lp, or ppdev are present)
and dmesg output of:
Any help greatly appreciated!
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/hal_parport.ko: No such device
[ 7411.404993] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 7411.417163] RTAI[math]: loaded.
[ 7411.567424] config string 'configuration string'
[ 7411.570138] PARPORT: ERROR: request_region(0xffff) failed
[ 7412.065364] RTAI[math]: unloaded.
[ 7412.069109] SCHED releases registered named ALIEN PEDV$D
[ 7412.079870] RTAI[malloc]: unloaded.
[ 7412.176047] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 7412.179559] I-pipe: head domain RTAI unregistered.
and
[ 8346.985411] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 8346.997155] RTAI[math]: loaded.
[ 8347.211470] config string '0 out'
[ 8347.214257] PARPORT: ERROR: linux parport 0 not found
[ 8349.836303] RTAI[math]: unloaded.
[ 8349.840323] SCHED releases registered named ALIEN PEDV$D
[ 8349.850123] RTAI[malloc]: unloaded.
[ 8349.948042] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
- Thank you received: 5874
04 Jan 2017 10:59 #85190
Replied by tommylight on topic Parallel Port Error - No Such Device
Did you enable the paraport in BIOS?
04 Jan 2017 13:47 #85204
What do you see with
cat /proc/ioports
Replied by andypugh on topic Parallel Port Error - No Such Device
cat /proc/ioports
- GingerPhil
04 Jan 2017 14:14 #85207
by GingerPhil
Replied by GingerPhil on topic Parallel Port Error - No Such Device
Wrong address set in Bios - too easy!
Time to create page: 0.135 seconds
