NVIDIA Jetson TK1
07 Jan 2017 15:53 #85412
by Deckerjwd
NVIDIA Jetson TK1 was created by Deckerjwd
is anyone looking at the NVIDIA Jetson TK1 for a machine controller
- Thank you received: 5918
08 Jan 2017 19:54 #85487
Replied by tommylight on topic NVIDIA Jetson TK1
That is an Nvidia CUDA procesing unit used for rendering and in some cases password cracking as they have hundreds of procesing cores for that type of work.
It is a magnificent piece of technology but Nvidia has proven not so friendly with open source, although their proprietary drivers work perfectly under Linux, so i am a bit confused about what can be done with that type of board.
If you have more info, please share.
I am fully aware of the enormous processing power they have, i just do not know if they can be used for Linuxcnc.
09 Jan 2017 01:45 #85497
Replied by PCW on topic NVIDIA Jetson TK1
Probably the first step here would be seeing if you can get decent latency on the hardware
with a Preempt-RT or perhaps Xenomai kernel. The only thing I could find on the net about RT and
the TK1 was not promising (ms latencies)
Time to create page: 0.060 seconds
