Can Asus Tinker Board run LINUXCNC
- reliantkill
- Topic Author
Comment here if you would like ("a wish") this implementation so we can create interest
- Thank you received: 5933
Also please post links to sites that have a bit of respect for the readers, not sites that force people to disable adblockers and use coockies specificaly for tracking.
Thanks for the info, i never heard of that board before right now.
TOM
and check whether you can get decent latency (and stability)
Either Xenomai or Preempt-RT kernels could be built
Note its not really true that PCs that run LinucCNC are getting hard o find,
as a matter of fact, many newer PCs have very good latency, even with Preempt-RT
which is probably the future real time kernel of choice.
freeby.mesanet.com/h97-g3258-preemt-rt.png
for example
www.theverge.com/circuitbreaker/2017/1/2...tinker-board-asus-4k
Specs for the Tinker Board include a quad core 1.8GHz ARM Cortex-A17 CPU, 2GB LPDDR3 RAM, four USB 2.0 ports, support for gigabit LAN and Bluetooth 4.0, 3.5mm audio jack, microSD slot, Micro USB for power, swappable 802.11 b/g/n Wi-Fi antennas, and a HDMI 2.0 port with support for 4K video.
- reliantkill
- Topic Author
he's been working on similar for a long time
forum.cncprovn.com/threads/7167-FPGA-Per...n-control-card/page4
forum.cncprovn.com/archive/index.php?t-7167-p-2.html
sorry its all in Vietnamese but thats life in the real world
tomp tjtr33 staggerlytomp with linuxcnc since RayHenry's first BDI
- Oliver Sedlacek
I also built a mold to build a shell for SBC's like the PI and tinker board etc....
Laser etched writing on the buttons is perfect !
linuxcnc.org/docs/devel/html/code/building-linuxcnc.html one of many sites on how to build
github.com/LinuxCNC/linuxcnc the git source that will work for tinkerboard using armbian and many others
forum.armbian.com/topic/10007-tinker-boa...-working-free-offer/ My patches, when I get around to it I'll offer an SD card image that has the FULL preempt RT kernel ready to go. when I get the GPIO working with linuxcnc I'll post a working image of everything. So all someone has to do is pop the SDCARD image into the tinkerboard and adjjust settings as needed and have a working cnc controller.
Attached file is the RT patch that works with armbian NEXT or 3.19 for those who want to roll there own.
