- Hardware & Machines
- Computers and OS's
- DigiPos 15" touch screen, how to get this up and running in LCNC
27 Apr 2017 14:48 #92217
by tecno
Have one old 15" DigiPos touch screen that I would like to get working. Sorry I do not have model number as it is partly dismantled.
Out from display comes a cable with VGA + RS232 + PS2 connector. VGA part is working OK with 1024x768 resolution.
Any tips on how to go about to set it up? I assume RS232 is for touch but what could PS2 be for?
Hints, tips and how to's is most welcome.
Cheers
Bengt
Cheers
Bengt
28 Apr 2017 03:01 #92243
Replied by rodw on topic DigiPos 15" touch screen, how to get this up and running in LCNC
It must be old!
I suspect that the PS2 connector should plug into a PS2 mouse connector on the PC. Any I've used have a USB connector for the touch overlay as they basically act as a mouse once configured.
28 Apr 2017 07:18 #92247
by tecno
Replied by tecno on topic DigiPos 15" touch screen, how to get this up and running in LCNC
It certainly is!
Used with my router/mach3 8-10 years ago and it was old at that time already, but as a horder I tend to save things that works.
So assuming PS2 is for touch what can the RS232 be used for?
How can I test and see if I get any reaction from the touch via PS2?
28 Apr 2017 09:41 #92250
I had a quick google. the PS2 could be an alternative interface to the DB9 for touch. It is slightly possible that the PS2 is for a barcode scanner. But sorry no drivers appeared. It might be possible to resurrect it with a touch screen overlay.
28 Apr 2017 10:14 #92252
by tecno
Barcode scanner is not possible as there is none. The cable out from display is with all 3 -in-1 cable and splits at PC-end.
So how to try resurrecting with *touch screen overlay* using Gmoccapy?
28 Apr 2017 12:59 #92264
Replied by andypugh on topic DigiPos 15" touch screen, how to get this up and running in LCNC
Does your PC have a PS2 port that you can try plugging the cable in to?
The serial connection will certainly need a driver.
A google search for "DigiPos" drivers took me to the Elo site, and they do seem to include drivers for serial interface screens.
support.elotouch.com/download/
28 Apr 2017 13:18 #92266
by tecno
What driver package to try?
28 Apr 2017 13:25 #92268
Actually, it might be easier than I thought.
forum.linuxcnc.org/9-installing-linuxcnc...hscreen-wheezy#71963
28 Apr 2017 13:31 #92269
by tecno
OK, will try that route as the wiki.linuxcnc.org/cgi-bin/wiki.pl?Debian_Wheezy link did not work at all.
Thanks Andy
Thanks Andy
28 Apr 2017 13:52 #92272
by tecno
Time to create page: 0.121 seconds
