64 Bit Chip Compatibility?
18 Oct 2017 14:49 #100512
by mac44mag
64 Bit Chip Compatibility? was created by mac44mag
First of all, my apologies if this is in the wrong place. New to Linux and a LinuxCNC virgin. I'm looking to put together a dual boot general purpose workstation (W10 and LinuxCNC). I've run across references to LinuxCNC not working and playing well on 64-bit processors. Does this mean that my workstation must utilize a 32-bit chip?
Thank you for any help you may be able to give.
Mac44mag
Mac44mag
18 Oct 2017 17:03 #100517
Replied by PCW on topic 64 Bit Chip Compatibility?
There's no reason you cannot run 32 bit LinuxCNC on a 64 bit processor.
In fact most PCs less than about 10 years old are 64 bit capable
Also LinuxCNC runs fine on 64 bit systems, _but_ the default real time kernel (RTAI)
does not, so if you want to run a 64 bit version of LinuxCNC, you must use Preempt-RT
Instead of RTAI
Instead of RTAI
18 Oct 2017 17:08 - 18 Oct 2017 17:33 #100518
by mac44mag
Replied by mac44mag on topic 64 Bit Chip Compatibility?
Thank you SO much for the reply.
I'll drop over to the original Debian site and pick up the i386 64 edition if I decide that I must run 64 bits.
Any problem running the 32 bit?
Thanks, again!
Thanks, again!
Last edit: 18 Oct 2017 17:33 by mac44mag. Reason: Change/rephrase/clarify question.
18 Oct 2017 22:02 #100530
No problems with 32 bit on LinuxCNC, its normally not a big memory space user
09 Jan 2018 20:06 #104214
by kestas
Replied by kestas on topic 64 Bit Chip Compatibility?
Hello.
I am one more new guy with similar situation.
I apologize for my misunderstanding, but situation is not 100% clear to me. I would be grateful for answer.
I have old computer with 64-bit processor (INTEL E2200). With this machine I want to learn to use LinuxCNC.
There is no need to me to install 64-bit OS. Does it mean that if I install 32-bit OS, I will be able to use RTAI?
Or system still will be able to handle well only Preempt-RT?
Thank you one more time.
09 Jan 2018 21:01 #104215
32 bit LinuxCNC works fine on 64 bit processors so you can run the standard Wheezy +RTAI linuxCNC version on your CPU
If you want to run a 64 bit version of LinuxCNC you must use Preempt-RT
(unless you want a lot of pain and suffering buildingt/testing RTAI 64 bit)
Note that Preempt-RT will typically have worse latency than RTAI so is not a good choice for
parallel port systems ( there are exceptions but as a general rule RTAI has better latency on most hardware)
- Hujtebesuka
23 Mar 2018 16:28 - 23 Mar 2018 16:29 #107755
by Hujtebesuka
Replied by Hujtebesuka on topic 64 Bit Chip Compatibility?
Betta LiveCNC
Try this one it worked like a charm on my 64bit system only problem was needed disable all cpu cores leave only one for best base jitter
linuxcnc-stretch-uspace-amd64-r10.iso working good on newest system and had my nvidia driver working out of box to
Last edit: 23 Mar 2018 16:29 by Hujtebesuka.
Time to create page: 0.348 seconds
