Connected to wifi but still no internet connection
i dont know if this is in the correct topic but i have a problem with my internet configuration.
i have a NUC pc with onboard wifi disabled and connected a wifi stick to reduce latency. i have a Mesa 7i80hd and i can control it perfectly over ethernet but i cannot connect to the internet. i can ping 8.8.8.8 but thats about it.
i heard i may have to edit something in the interfaces file (etc/network/interfaces) but i dont know what i have to add there.
so far this is what the interfaces file contains:
auto lo/niface lo inet loopback
auto eth0
iface eth0 inet static
address 192.168.1.1
hardware-irq-coalesce-rx-usecs 0
if anyone has an idea please let me know
thanks
I would suggest setting the real time Ethernet connection to
host: 10.10.10.1
7I80: 10.10.10.10 (IP jumpers W1 down, W2 up)
- Thank you received: 5945
i have written "nameserver 8.8.8.8" and "nameserver 8.8.4.4" in the file resolv.conf in "etc/" and this way i did get internet, but only for like 1 minute, then it was ultra slow, almost so slow i thought i had no internet at all. Also i have to edit the file everytime i reboot.
i changed the ethernet connection according to tommylight but it doesnt seem to make a change. also the network manager says: ethernet device is not managed.
however i still can connect to the mesa card with linuxcnc (probably because in the hal file i still have the ip adress 192.168.1.121).
i have the feeling my general network is kind of broken and needs a reset.
basically i have little clue what i am doing
thanks
The way to fix this as I mentioned before is to set the 7I80HDs address to 10.10.10.10 (via the jumper) and then set the Host Ethernet address to 10.10.10.1 (This is actually fine since there _must_ be no DNS or gateway access on this port)
thank you
Symptoms as follows:
Connects to wifi AP easily
Works intermittently
Stops working after a few seconds ( depending on load )
Ping to local non rout-able addresses works
Ping to public addresses works for some, some do not
Unplug and plug makes it work for some time
repeat.
They are a pain to use, are VERY picky about placement so try moving it around on an USB extension cable, that is what i do when i have to use this one.
PCW you said:
Its likely you have a IP address overlap
host: 10.10.10.1
but tommylight wrote this in his thread:
(forum.linuxcnc.org/27-driver-boards/3559...t-mesa-boards#121458)- write the address as 10.10.10.2 up to 10.10.10.9 ( never 10.10.10.1 or 10.10.10.10 ), or anything from 11 to 254
so what should i do?
btw. it is a Edup Wireless Usb stick and i mostly have 3/4 Bars Signal strength
Anyways thanks for your help guys!
I am using a Tenda wifi usb for the last 3 months, it is all good.
