Script for automated testing of computer latency.
- Topic Author
- Online
- Thank you received: 5939
20 Jun 2020 22:20 - 02 Oct 2020 17:27 #172199
Script for automated testing of computer latency. was created by tommylight
Attached is a script that can be used to test latency on PC's and laptops intended for use with LinuxCNC
The script is made by user "seuchato", all credits go to him for the effort put into this.
-Does not work on Debian Wheezy Linux.
---How it works?
-It uses latency histogram to test and generate latency info,
-It starts several (default is 5) glxgears and resizes them several times to stress the graphic subsystem,
-It opens Firefox pointing to a video of surfing the waves in Cape Town, and resizes the video after a while, leave autoplay on if doing a longer run,
-It also checks the hardware and software used,
-By default it will run for 2 hours using base and servo threads,
-It will exit at any latency bigger than 25000ns for the base thread and 1000000ns for the servo thread,
-It creates two files with all the relevant data form each run saved on them for comparison or posting here:
forum.linuxcnc.org/18-computer/39371-res...or-use-with-linuxcnc
---How to use?
-Extract the downloaded zip file, double click on it and choose "run in terminal"
-If that does not work, open a terminal, CD to where the extracted file is and paste this
sudo ./lcnc-hw
-At the menu, if you want to run with default settings, just press enter,
-If you select "No" other menu's will be presented , so follow the instructions on screen,
Use this topic only to post further improvements to the script, issues if any, and suggestions on improving it.
Do not use this topic for posting test results, use the link above for that.[/color
This script is offered "as is" and as such holds no liability, implicit or otherwise.
Released under the LGPL licence:
---How it works?
---How to use?
sudo ./lcnc-hw
# Script to read the releveant parameters to build a more recent #
# database for linuxcnc pc hardware #
# I provide the script as is. No warrenties are granted, not #
# even that the script is fit for the intended purpose. #
# I put it under the LGPL Version 3. a copy of this license can #
# found here: https://www.gnu.org/licenses/lgpl-3.0.html #
# Targets, I hope to meet: #
# . Comparability: hopefully this proposal leads to comparable #
# latency test data. #
# . Repeatabilty: given the fast change in PC hard/software #
# probably hard to achieve, if asked to be consistent. #
# . Still, we intend to run cnc machines with potential of #
# danger using stock pc hardware. Therefore we should at least #
# try to figure out what suits, is acceptable and/or reliable #
# enough. Could result in a potential conflict of goals though. #
# V 20200624 #
# added lookup for sound/pcspkr chipset #
# Message when CTRL-C is pressed to standby for a graceful exit #
# Some info on progress when installing software #
# clearer output when doing latency test #
# I put the script under LGPL license #
# V 20200619-c #
# general rework, using functions instead of spaghetti code, #
# with the help of"dialog" added : #
# choice of base thread or no base thread #
# choice of time to run #
# option for base thread at 100000 #
# firefox as default browser #
# option to quit by pressing ^C #
# V 20200615 #
# initial version #
Last edit: 02 Oct 2020 17:27 by tommylight. Reason: New file
The following user(s) said Thank You: Mike_Eitel, seuchato, phillc54, chimeno, arvidb, Clive S, berntmartin
22 Jun 2020 09:23 #172309
by seuchato
Replied by seuchato on topic Script for automated testing of computer latency.
Hi all, Il add:
chris
- Lookup for chipset, check if pcspkr and/ or any sound modules are loaded
- Message when CTRL-C is pressed to standby for a graceful exit
- Some info on progress when installing software
- clearer output when doing latency test
chris
The following user(s) said Thank You: tommylight, berntmartin
24 Jun 2020 09:47 #172556
by seuchato
I am a bit puzzled about the output taken from
here
@ chimeno: could you kindly run the following command and post all output here?
Tia
chris
RAM related data:
Maximum Memory Module Size: 1024 MB
Maximum Total Memory Size: 4096 MB
Maximum Capacity: 4 GB
Installed Size: 2048 MB (Single-bank Connection)
Enabled Size: 2048 MB (Single-bank Connection)
Installed Size: Not Installed
Enabled Size: Not Installed
Size: No Module Installed
sudo dmidecode -t memory | grep Maximum | sed "s/\t//g"
sudo dmidecode -t memory | grep Size | sed "s/\t//g"
Tia
chris
- Topic Author
- Online
24 Jun 2020 10:09 #172561
Replied by tommylight on topic Script for automated testing of computer latency.
Here is what i get:It seems Chimeno has 3 DIMM modules of 2GB installed but only 4GB are supported so 2 are not used
cnc@shop:~$ sudo dmidecode -t memory | grep Maximum | sed "s/\t//g"
[sudo] password for cnc:
Maximum Capacity: 16 GB
cnc@shop:~$ sudo dmidecode -t memory | grep Size | sed "s/\t//g"
24 Jun 2020 10:18 #172564
by chimeno
Replied by chimeno on topic Script for automated testing of computer latency.
Hello @seuchato
if there is no problem, here you are.
Hi @tommylight
you are right!! a memory module had some unexpected errors.
Greeting
Chimeno
Hi @tommylight
you're right!It seems Chimeno has 3 DIMM modules of 2GB installed but only 4GB are supported so 2 are not used
Greeting
Chimeno
24 Jun 2020 11:45 #172570
by seuchato
@ chimeno: I suggest you should run the machine according to specs, using 1024 MiB Ram modules, thanks anyway
@ tom: Thanks, wouldn it seem that chimeno's PC uses two Dimms and supports surprisingly 2048 MiB per Dimm? Maybe he can get a good machine by just using two 2GB dimms, but I also suggest, he should set isolcpus=1,2,3 and idle=poll.
Got the new version ready. If I send it to you by pm, could you kindly exchange it against the old version in your first post?
greez
chris
greez
chris
The following user(s) said Thank You: chimeno
- Topic Author
- Online
24 Jun 2020 11:57 #172571
It is working for him, maybe just removing the not used DIMM.
Most older PC's will support one sided 2GB modules even if it says 1GB, but will completely ignore one side of the two sided modules, reporting it as 1GB although it is a 2GB module.
Isolcpu has not much of an effect on newish PC, so it will just make the PC very sluggish.
There is no PM here, so just attach it here and i will move it to the original post.
Thank you.
Thank you.
24 Jun 2020 12:20 #172574
by seuchato
What is a suitable license for this script?
LGPL?
I want it to be free, for anyone to use.
greez
chris
LGPL?
greez
chris
- Topic Author
- Online
24 Jun 2020 13:02 #172577
That seems appropriate.What is a suitable license for this script?
LGPL?
24 Jun 2020 13:38 - 24 Jun 2020 13:39 #172583
by seuchato
here you go
Kinda changelog:
greez
chris
Kinda changelog:
# V 20200624 #
# V 20200619-c #
# V 20200615 #
# initial version #
greez
chris
Last edit: 24 Jun 2020 13:39 by seuchato.
