Massive Latency, and no PCI port Acer
18 Jul 2020 19:20 #175066
by riversvic
Massive Latency, and no PCI port Acer was created by riversvic
I am not computer savy... I have an Acer Aspire X AXC-605-UB1F I thought would make for a good computer with a small package and potentially more modern and better performance then my other spare desktops. After initial install of Mint 19.3 Mate and LinuxCNC using the forum post I ran a latency and it was 12MS. I have some other video cards but the current Intel HD Graphics card is internal to the mother board? That leads me to the computer only having a PCIe and PCIe 16x(I thought was PCI) ports available, not giving me many options for mesa cards. Should I look for another computer? I have been using an HP EliteBook 8470p Laptop running debian and 2.7 I installed in 2018 and dock with parallel port but running external monitor and keyboard bumped the latency up above 50k.
- Thank you received: 5957
18 Jul 2020 19:25 #175068
Replied by tommylight on topic Massive Latency, and no PCI port Acer
What does
uname - a
in a terminal say?
Did you disable everything regarding hyperthreading, speed step, power saving, C states, etc in BIOS?
uname - a
in a terminal say?
18 Jul 2020 20:22 #175075
by riversvic
Replied by riversvic on topic Massive Latency, and no PCI port Acer
uname: extra operand `-'
Try `uname --help' for more information.
18 Jul 2020 20:26 #175076
My bad,
uname -a
uname -a
18 Jul 2020 20:59 #175079
by riversvic
Linux riversvic-Aspire-XC-605 5.4.0-0.bpo.4-rt-amd64 #1 SMP PREEMPT_RT Debian 5.4.19-1~bpo10+1 (2020-03-09) x86_64 x86_64 x86_64 GNU/Linux
18 Jul 2020 21:34 #175084
Reboot, hold down ctrl+shift till you get the Grub menu, choose advanced .... , chose the line that contains the above kernel,
Test latency again, it should be better.
But, disable the BIOS stuff, no amount of kernel magic will help if you have hyperthreading and speed step active.
wget http://security.debian.org/debian-security/pool/updates/main/l/linux-signed-amd64/linux-image-4.19.0-9-amd64_4.19.118-2+deb10u1_amd64.deb
sudo gdebi linux-image-4.19.0-9-amd64_4.19.118-2+deb10u1_amd64.deb
18 Jul 2020 23:17 #175088
by riversvic
I'm struggling to get to the grub menu
19 Jul 2020 04:25 #175109
by riversvic
I was able to get into the Grub Menu by changing some boot options and hitting esc on reboot. latency is down but still in the 9m. I dont think there is anything else to disable in the BIOS
21 Jul 2020 09:24 - 21 Jul 2020 09:34 #175316
by seuchato
Replied by seuchato on topic Massive Latency, and no PCI port Acer
Kindly post the result of:
see the line with "GRUB_CMDLINE_LINUX_DEFAULT". You could try setting some or all of the following options:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash intel_idle.max_cstate=0 processor.max_cstate=1 idle=poll isolcpus=x";
for "x" see wiki.altervista.org/cs/kernel_boot_parameters
If you use my script here and post the results, more details about the pc will be available.
hth
greez
chris
cat /etc/default/grub
hth
greez
chris
Last edit: 21 Jul 2020 09:34 by seuchato. Reason: re to script added
22 Jul 2020 01:09 #175368
by riversvic
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
# info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=0
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
GRUB_DEFAULT=0
GRUB_TIMEOUT=0
Time to create page: 0.184 seconds
