thinking of trying my ASUS Q87M-E motherboard
the motherboard has a i3 4160 at 3.6GHz, with 16GB DDR3. this was previously my CAD/CAM computer.
the other option is to continue using my Dell PowerEdge R200, but it has only PCI-E connections, so that limits what Mesa cards i can use (the ASUS board has two PCI-E, and two PCI slots).
what do you all think, upgrade to a Mesa system, or "if it ain't broke, don't fix it", and stay with the current system with parallel ports?
i am trying to improve non-machining rapids, as it is painfully slow to move from one end of my (approximately) 4 foot by 4 foot woodworking router table, to the other.
i also realize my use of steppers, over servos (i like the sounds they make...) limits the speed of my rapids as well.
just trying to weigh my options...
~Travis
- Thank you received: 5984
Give us some more info, like what driver, what voltage they run on, what is the motor inductance or winding resistance, as all of this might be more speed limiting that the parallel port.
As for Mesa boards, it is simple, there is only one question there : can you afford one?
Might be a bit biased on this, but i have and had over 70 or 80 of Mesa boards.
i will get this info tomorrow, as i lost the data sheets for the steppers, and will have to test them for winding resistance. what i do know, is the voltage is 36V, and the drivers are Leadshine DM422.
funny you should ask... i could when i wrote this, but today i had a major truck issue, so currently i can't afford one. but i will get the stepper winding resistance tomorrow, and see if we can tweak more speed out of them.
~Travis
anyway, i am currently running the live LinuxCNC ISO disk (2.8, buster, preempt) right now, and have the latency test running on the ASUS Q87M-E. so far, servo thread max interval: 1030334, and base thread max interval: 44286. i don't seem to remember, that good or bad?
at idle, the max jitter is 82914, and 24621.
for what it is worth, the install hangs after configuring network, either graphic install, or other. i suspect my USB DVD-ROM drive is the root cause. i will try burning to a USB thumb-drive in a bit.
~Travis
the MD5 i get from the ISO is: 41b71c4956c0c89033a99a590ebaefec linuxcnc-2.8.0-buster.iso
that correct?
downloading the linuxcnc-2.7.14-wheezy.iso as well, just as a more stable base (will update to 2.8)
~Travis
i will also need to buy some breakout boards and ribbon cable to connect it all. but at least i think i am on my way toward upgrading. this motherboard (the ASUS Q87M-E) has a pair of PCI slots, as does an older motherboard i have kicking around (needs a BIOS battery..). the current computer that is connected to my machine, a Dell PowerEdge R200, does not have PCI slots (only PCI-E). but i never really liked the large rack server sitting on my desk, taking up too much space. at least with a regular tower case, i can tuck it away, out of the way. and it is easier to clean the dust out of...
as for the component specs stated before, the drivers, i think, are Leadshine DM542E, as that is what i have for a PDF manual... will confirm when i head out later this morning to get the stepper winding resistance. really, i need to write all these specs down somewhere for future reference.
~Travis
Those are so far the only ones that work properly.
so, just for something to try, i installed the older motherboard, that i used with my first LinuxCNC build, and it wouldn't detect the SATA drive... will try more in a bit (taking a mental break).
so, as a failsafe, i have the Dell PowerEdge R200 that is running my machine now, but it doesn't have any PCI slots for the Mesa card i just bought... has anybody had any luck with a PCI-E to PCI adaptor?
www.ebay.com/itm/PCI-E-Express-X1-to-Dua...0-Cable/143648841107
it wouldn't be as clean looking of an install, and i would still be using the R200 server chassis, but would it work?
if i can't figure out how to get one of the motherboards i have working right, my options are very limited.
~Travis
Remove the existing Dell drive, label it "do not touch" and put it beyond arms reach, just to be safe;
remove the drives from other PC's and insert one of them in the Dell, boot from USB, install as usual, remove the drive and put it back on where it belongs,
rinse and repeat,
After installing the other drives, insert back the "far and away" drive on the Dell.
anyway, the drivers are in fact DM542E, from Leadshine, and the stepper winding resistance is 1.2ohm. i checked one stepper, as it was cold, and i didn't want to fire up the heat if i was only going to be there for long. i assume the others are quite similar. though, the Z is different from the X and Y motors, and i don't know what one i tested...
anyway, off to work on the Honey-Do list, around the house.
~Travis
