Can't boot from USB - Debian only
24 Oct 2022 16:03 #254917
by spumco
Can't boot from USB - Debian only was created by spumco
Tearing my hair out over this one...
I'm trying to install a clean Debian on my dual-boot PC and failing. Burn USB, open bios, and select the USB in 'boot override.'
When I select the USB drive, nothing happens when I press enter. The PC blinks and returns to the boot-override bios screen. No error message, but PC does not recognize the USB as bootable.
Changing the boot order to make USB first also fails - USB gets ignored and it boots to grub.
When I do the exact same process with Mint (19, 21) and MX21 there are no problems. Burn a USB with Rufus and it boots from USB fine. OS loads or installs with no issues.
I've D/L'd every version of Debian (10, 11, 12, non-free, net install, etc.) I can find and burned bootable USB using Rufus. Tried MBR, GPT, every option in Rufus to see if something works. No joy.
Secure boot is off, fast boot is off.
What is different about Debian from Mint and MX that makes my PC hate it?
24 Oct 2022 16:15 - 24 Oct 2022 16:16 #254918
by arvidb
Replied by arvidb on topic Can't boot from USB - Debian only
Not sure what the problem is but your mention of options in Rufus (which I've never used) makes me a bit suspicious. Whatever program you use shouldn't have any options for the writing, it should just write the image byte-by-byte to the stick without touching anything. (Make sure you write the image directly to the device and not to some already-existing partition on the device.)
Last edit: 24 Oct 2022 16:16 by arvidb. Reason: spelling...
24 Oct 2022 16:27 #254919
by spumco
Replied by spumco on topic Can't boot from USB - Debian only
Rufus is the Win program identified in the Debian Install wiki as the preferred method of creating a bootable USB.
(from Debian wiki)
To create a bootable USB drive from Microsoft Windows or Mac OS a usable choice is Rufus .
The wiki mentions ISO and DD mode - I've tried both. Multiple USB drives, tried all USB ports. Same result...
(from Debian wiki)
- Online
- Thank you received: 5946
24 Oct 2022 16:41 #254920
Replied by tommylight on topic Can't boot from USB - Debian only
Try Balena Etcher, and do the md5sum for the ISO.
www.balena.io/etcher/
24 Oct 2022 17:54 #254928
by spumco
Thanks Tommy. I'll try that soon as I get home and report back.
24 Oct 2022 21:11 - 24 Oct 2022 21:12 #254960
by spumco
No dice - same behavior. I can see the USB stick in bios and can select it for boot override - but nothing happens. Press enter, screen blinks, and it's on the same bios page.
I ran Balena Etcher but didn't see an option for md5sum... is this something in Etcher, or do I have to do it elsewhere? (on a Win PC)
Last edit: 24 Oct 2022 21:12 by spumco.
- Online
24 Oct 2022 21:24 #254961
As i am not very good at explaining, have a look at the top of this page please:
www.debian.org/download
24 Oct 2022 23:17 #254969
by spumco
Thanks. I can't figure out the MD5 thing, but I downloaded the iso(s) from the debian site.
I'll try again with the full ISO and not the net version.
- Online
24 Oct 2022 23:26 #254970
Oh well, i was sure that would be a better explanation, it is not!
On Linux, use "transmission" to download the ISO, it will make sure it is correct.
On windoze, i have no clue what checks that.
24 Oct 2022 23:47 - 24 Oct 2022 23:59 #254972
by spumco
Good idea. I've got Mint running on it now, maybe I'll try downloading it on the target machine.
Just doesn't make sense since Mint and MX work fine. It's like Debian is missing some function/feature/file that my PC requires.
EDIT - no dice. I'm stumped.
Last edit: 24 Oct 2022 23:59 by spumco.
Time to create page: 0.187 seconds
