Hardware choices
- grey1beard
18 Jul 2009 15:29 #568
by grey1beard
Hardware choices was created by grey1beard
I've currently got latency periods of the oder of 64000.
I've tried reading all the advice and hardware choices, but what there is seems to be inconsistent, to put it mildly.
Is it purely down to chance on what your particular combination of cpu/hdd/video card comes up with ?
Where do you start - different video card or different hdd ?
My current system is GA-5AX / amd K6-2/500 / 655Mb / ATI C-1 8M, and at the moment the whole process is getting pretty depressing.
Encouragement would be welcome.
- grey1beard
18 Jul 2009 16:54 #569
by grey1beard
Replied by grey1beard on topic Re:Hardware choices
Further to the above, I've found that my mobo has a ACPI setting at irq 9, but there appears to be no bios control over this.
I've noticed the screen goes blank after a period yet to be determined, and though I've disabled all the bios controls I can find, I can't stop it happening.
Have I made a poor choice with the mobo ?
18 Jul 2009 20:51 #572
by robh
Replied by robh on topic Re:Hardware choices
Hi,as you have found motherboard is most killer but grafics cards also play a role too i find.
(many things also but the main two above is what i find)
motherboard i try to stick to well known support chipsets, Intel, Via etc that board u like to looks like it has a ALi Aladdin V so this may be cause, as it may not be that well support in the kernel.
also grafics cards, i try start away from ones that try and use system memory as part of the memory help reduce the CPU/mem load and time taken to do that process.
check out the wiki to see what hardware people are using and what looks to work for the setup u need etc.
rob
rob
- grey1beard
18 Jul 2009 21:06 #573
by grey1beard
Thanks for the input robh.
I just had a brainwave. Swapped hdd's with a system I have already in use, a compaq desktop, and Jackpot.
Now getting latency round the 10k mark with glxgears running.
The downside is that the other system doesn't boot up, so I'm not out of the woods yet, but at least something positive at last.
18 Jul 2009 21:31 #574
by robh
putting drive in compaq from truble system worked? or other way around?
always good fun trying to find what is different or changed to cause the bad setup.
good luck
rob
good luck
rob
19 Jul 2009 11:33 #577
by BigJohnT
Replied by BigJohnT on topic Re:Hardware choices
John,
I have one computer that I could not even get Ubuntu to install from the LiveCD until I put a new hard drive in it. I don't know if it was the windows install that borked it or the hard drive itself...
- grey1beard
19 Jul 2009 16:43 #578
by grey1beard
Hi all.
robh - the hdd into the compac system worked srtaight away, without me touching the bios at all !
Mind you, I can probably mess that up pretty quickly if I try.
The windos98 hdd, placed into the newer system went completely base over apex, and I'm still sorting it, using a third desktop to do a compare and contrast(I never throw anything away if I can help it. )
Big J - I've lots of bits I can swap around. I'm a great believer in "you never know when that grunge widjet might come in useful"
Regards
JohnB
Regards
JohnB
