Problems with user defined M1nn codes
- garymcrobertpdx
13 Dec 2009 23:24 #1310
by garymcrobertpdx
Problems with user defined M1nn codes was created by garymcrobertpdx
Once again I need help. I am attempting to control a parallel port
output pin via the user defined M1nn codes. I have done as instructed
in the EMC V2.3 user manual chapter 12. M Codes. Despite many
attempts to guess the solution EMC2 fails to execute the M code
and issues the “unknown M code error”.
The PROGRAM_PREFIX portion of the file my-mill.ini points to
/home/me/emc2/nc_files
I have placed the external program file M100 in this directory.
I have tried copying the example on page 97 of the user manual
And also tried using M101 code example I found in the examples
Folder.
None of these have worked who knows the correct magic incantation
To make a user defined M code work????
Folder.
Time to create page: 0.073 seconds
