G code Generators
27 Mar 2009 16:06 - 26 Jun 2012 23:48 #14
by BigJohnT
G code Generators was created by BigJohnT
The Wiki has a large gathering of G code generators...
wiki.linuxcnc.org/cgi-bin/wiki.pl?Simple...NC_G-Code_Generators
Last edit: 26 Jun 2012 23:48 by BigJohnT.
The following user(s) said Thank You: Bullet_Head, Dinuka_Shehan
- Bloumielies
09 Jun 2014 17:41 #47802
by Bloumielies
Replied by Bloumielies on topic G code Generators
Hi John
Could you possibly assist me. I am trying to get the arc buddy 1.3 to assist me to generate g-code for my cnc machine. As soon as I enter all the parameters I need on the GUI and try to exit and send it to Axis, the transfer of G-code does not happen. I have tried the others like Face and drill and they all work. After a while of having the time circle (progress circle running) I stop the GUI and get the following message "File ended with no percent sign or program end".
I see that in the website was two link for arc buddy and I cannot get any of the two to work.
I am a beginner at this. Is there maybe something that I might be missing or is there maybe another version available?
Thank you
Thank you
09 Jun 2014 18:25 #47804
by BigJohnT
Replied by BigJohnT on topic G code Generators
Just to be sure you opened arcbuddy.py from Axis?
I'll check it out and see what it is doing.
JT
JT
The following user(s) said Thank You: Bloumielies
- Bloumielies
09 Jun 2014 18:32 #47805
by Bloumielies
Hi John
Yes, precisely the way that is explained on the website. I also found now that the engrave.py does the same.
Thank you
Thank you
09 Jun 2014 18:34 #47806
by BigJohnT
For starters there is a typo in the WriteToAxis code... and it only outputs the arc code so it will not be a complete program ie there is no M2 or starting point.
Be Back in a Bit.
JT
Be Back in a Bit.
JT
09 Jun 2014 19:09 #47807
by BigJohnT
Ok, download 1.4. I've fixed the send to Axis button to be a tad useful however there is no Z...
JT
JT
09 Jun 2014 19:15 #47808
by BigJohnT
The engraving ones are Lawrence's work... what does engrave-11.py do?
JT
Hi John
Thank you
JT
- Bloumielies
10 Jun 2014 13:28 #47833
by Bloumielies
Hi John
Thank you very much, it seems to work now 100%. Appreciate it.
Maybe just a remark. I see the cutter does not clear the arc when finished with the cutting. Suggestion if I could maybe to just clear the work piece after cutting.
I will test the others now and get back if I see some other errors.
Thank you
Thank you
- Bloumielies
10 Jun 2014 13:34 #47834
by Bloumielies
Hi John
The following gives me the same error as before on the arc buddy about the no percent sign and program end:
1. boltcircle2
2. counterbore
3. drill
4. engrave-11
The ones not mentioned works correct.
Kind regards
1. boltcircle2
2. counterbore
3. drill
4. engrave-11
Kind regards
10 Jun 2014 18:11 #47845
by BigJohnT
Yes Arc Buddy was never intended to actually generate a working program only to generate the arc that you would cut and paste into your G code.
JT
Hi John
Thank you
JT
