G code Generators
10 Jun 2014 18:25 - 10 Jun 2014 18:26 #47846 by BigJohnT
BigJohnT replied the topic: G code Generators
Bloumielies wrote: Hi John
The following gives me the same error as before on the arc buddy about the no percent sign and program end:
1. boltcircle2
2. counterbore
3. drill
4. engrave-11
The ones not mentioned works correct.
Kind regards
Counterbore you must select Insert EOF if you are not adding the generated code to an existing G code file.
The rest are not my programs.
Looking at the output of boltcircle and it is clearly only a code snippet not a complete G code program. Looking at the code and I see Dan never intended boltcircle to be opened in Axis as there is no send to Axis button.
JT
Last Edit: 10 Jun 2014 18:26 by BigJohnT.
Time to create page: 0.049 seconds
