G code Quick Reference
04 Jan 2013 22:22 #28379
by BigJohnT
G code Quick Reference was created by BigJohnT
I've created a
G code quick reference
that is organized by modal group. This just a quick reference not a replacement for the docs. I just find it faster to navigate to the code I forgot a parameter for.
Enjoy
Enjoy
05 Jan 2013 17:03 #28395
by Rick G
Replied by Rick G on topic G code Quick Reference
Nice work John, I think that does make it easier to find the codes faster!
Rick G
Rick G
The following user(s) said Thank You: BigJohnT
11 Jan 2014 06:38 #42594
by fannlow
Replied by fannlow on topic G code Quick Reference
Hi and thanks for the references, its plenty helpful!
need to also know if these linuxCNC "G" & "M" codes are the same we saw over fanuc?
because I'm trying to edit the original or generic fanuc 3x, 4x, 5x in the masterCam X7.
looking over the .pst files that is in existance with the software pack, it seems some of what they are adding to the file is not actually needed by linuxCNC.
that's why I'm asking if anything else is difference or at least that I know what linuxCNC needs and doesn't.
that way, I can edit the post processors to output the correct paths and codes to linuxCNC so I don't have to re-edit or delete out every post I made from masterCam X7.
many many thanks !
many many thanks !
11 Jan 2014 19:24 #42614
by emcPT
Replied by emcPT on topic G code Quick Reference
There are many differences between the Fanuc code and the Linuxcnc one.
It also depends if you are talking about a milling machine or a lathe, or other.
13 Jan 2014 00:23 - 13 Jan 2014 00:31 #42659
by fannlow
it will be on a mill machine.
currently running on 3 axis.
and another mill on 4 axis.
but, if I can use the mastercam x7 generic or fanuc processor then change it to the linuxCNC, it would be easier for me to follow the same format for all the other 4 or 5 axis.
posting the file or format here will also help others in need of finding or editing a post processor much easier.
but am needing to find out what's the main differences, example compensation or "G" numbers being different for other functions?
have tried out the previous EMC2 pp from mastercam v9, but turns out after upgrading it to X7, the linuxCNC has some "O" or "A" letters that are not required, as well as tool table calling and tool number.
hence, I'm thinking of just making it simple to format the pp.
let me know if you need any sample files from mastercam?
I'm uploading the generic and fanuc pp from the mastercam X7 here for references.
am still reading up on the things that was posted, lots of good information on this forum, still referencing them.
Last edit: 13 Jan 2014 00:31 by fannlow.
13 Jan 2014 00:32 #42661
by fannlow
not sure why i am unable to post the generic fanuc 3x here...
if you need, please send me email.
19 Jul 2016 09:24 - 19 Jul 2016 09:25 #77631
by cparsons
Replied by cparsons on topic G code Quick Reference
Picking this up after a long absence and saw your G code quick reference link - looks to be very useful - but the links inside it appear to be broken?
Regards
Chris Parsons
Regards
Chris Parsons
Last edit: 19 Jul 2016 09:25 by cparsons. Reason: typo
19 Jul 2016 09:31 - 19 Jul 2016 10:02 #77632
by BigJohnT
Replied by BigJohnT on topic G code Quick Reference
Yes the document links have changed since I made that up. It is fixed now. If someone can check them to make sure they all work that would help.
JT
JT
Last edit: 19 Jul 2016 10:02 by BigJohnT.
The following user(s) said Thank You: cparsons
19 Jul 2016 10:53 #77634
by cparsons
I've just run it through a link checker and it has found 466 valid URL's and 0 invalid URL's so good job!
Thanks very much
Chris
Thanks very much
Chris
04 Oct 2022 04:57 #253414
by swarren
Replied by swarren on topic G code Quick Reference
The link seems broken again. Can it be fixed? If not, perhaps unpin the topic?
Time to create page: 0.095 seconds
