G96 CSS problem
26 Mar 2014 00:35 #45245
by jbunch
G96 CSS problem was created by jbunch
I am having a problem with G96 CSS.
With a start dia of 4.6 inches, D=1000 S=300 My spindle comes up to speed the joints move to start of cut but I do not get a spindle at speed and the joint sits.
It is the same for an X or a Z movement. My lathe is a backtool and this is done with the spindle in reverse or CCW. Testted with CW same thing.
As I raise the SFM higher and higher it will eventualy start to cut. But the speed is well above the 1000 rpm max and the system will take the spindle to absolute max 2500 rpm.
This started with the Gmoccapy GUI so I setup Touchy, I am also seeing the same behavior with Touchy. Also now seeing it with AXIS.
For now I have inserted G97 and it works at a fixed speed no CSS.
Jim
setp hm2_5i20.0.encoder.02.counter-mode 0
setp hm2_5i20.0.encoder.02.filter 0
setp hm2_5i20.0.encoder.02.index-invert 0
setp hm2_5i20.0.encoder.02.index-mask 0
setp hm2_5i20.0.encoder.02.index-mask-invert 0
setp hm2_5i20.0.encoder.02.scale 2000
net spindle-index-enable motion.spindle-index-enable <=> hm2_5i20.0.encoder.02.index-enable
net spindle-revs motion.spindle-revs <= hm2_5i20.0.encoder.02.position
net spindle-enable <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-speed-out abs.2.in <= motion.spindle-speed-out
# Change velocity to RPM
setp scale.1.gain 60
net spindle-velocity motion.spindle-speed-in near.0.in2 scale.1.in <= hm2_5i20.0.encoder.02.velocity
# End Velocity to RPM
# *** Spindle speed control
# PWM Generator signals/setup
setp hm2_5i20.0.pwmgen.02.output-type 1
setp hm2_5i20.0.pwmgen.02.scale 0.00094
net spindle-enable hm2_5i20.0.pwmgen.02.enable <= pid.2.enable
net spindle-vel-cmd pid.2.command <= abs.2.out
net spin-pid-out pid.2.output hm2_5i20.0.pwmgen.02.value
# *** End
# *** spindle at speed
setp near.0.scale 1.2
net spindle_speed_reqst_scaled near.0.in1 <= motion.spindle-speed-cmd-rps
#net spindle_ena_spindle_spd and2.12.in1 <= near.0.out
#net spindle_for_rev and2.12.in0 and2.3.in1 <= or2.5.out
#setp near.0.scale 1.2
#net spindle_speed_reqst_scaled near.0.in1 <= motion.spindle-speed-cmd-rps
# *** End Spindle at speed
Jim
- skunkworks
- Thank you received: 148
26 Mar 2014 02:44 #45253
by skunkworks
Replied by skunkworks on topic G96 CSS problem
a shot in the dark - but I think you want motion.spindle-speed-out (it is in rpm though) (or out-rps) I assume
sam
sam
26 Mar 2014 02:57 #45255
by BigJohnT
Replied by BigJohnT on topic G96 CSS problem
Open Show Hal Configuration and put the near in's in a watch window and run your spindle.
JT
JT
26 Mar 2014 04:54 #45262
by newbynobi
Replied by newbynobi on topic G96 CSS problem
I do not see pid.2.feedback connection, how does the pid work?
Pwm scale shojld be max spindle rpm
I did mention a link in the gmoccapy thread, did you take a look at it?
I will post a working config, next time i am on my dev pc.
Norbert
Norbert
26 Mar 2014 06:32 - 26 Mar 2014 06:38 #45265
by jbunch
Replied by jbunch on topic G96 CSS problem
JT,
In midi mode all works well and I get spindle at speed. I only have a problem when using G96 CSS.
Synced spindle motion threading is OK also.
Jim
Norbert,
The pid does not realy use feedback it is scaled using setp hm2_5i20.0.pwmgen.02.scale 0.00094 and FF0
Jim
Jim
Norbert,
Jim
Last edit: 26 Mar 2014 06:38 by jbunch.
26 Mar 2014 18:37 - 26 Mar 2014 18:41 #45275
by BigJohnT
What version of LinuxCNC are you using? I use CSS all the time on my CHNC with 2.5.3 and most of my ngcgui subroutines use G96.
JT
JT
Last edit: 26 Mar 2014 18:41 by BigJohnT.
26 Mar 2014 18:57 #45276
by BigJohnT
Here is the spindle section of my CHNC.
JT
#Spindle uses encoder.02 and pwmgen.02
#spindle scales
addf scale.0 servo-thread
addf scale.1 servo-thread
#10v/6000rpm=0.001667
setp scale.0.gain -0.0002
# offset for spindle
#setp scale.0.offset 0.0001loadrt pwmgen output_type=0 # This creates a 1Hz signal
#load abs comp make spindle RPM pos
loadrt abs count=3
addf abs.0 servo-thread
addf abs.1 servo-thread
addf abs.2 servo-thread
#spindle speed out limits
loadrt limit1 count=1
addf limit1.0 servo-thread
setp limit1.0.min -6000
setp limit1.0.max 6000
#set scale and pwm
setp hm2_5i20.0.encoder.02.scale -4096
setp hm2_[HOSTMOT2](BOARD).0.pwmgen.02.output-type 1
net spindle-speed-limit motion.spindle-speed-out => limit1.0.in
net spindle-speed-limit-out limit1.0.out => scale.0.in
net spindle-speed-DAC scale.0.out => hm2_5i20.0.pwmgen.02.value
net spindle-rpm => abs.1.in
net spindle-speed-abs <= abs.1.out
#spindle enable
net spindle-enable-req motion.spindle-on => and2.1.in0
net spindle-brake-sensor hm2_5i20.0.gpio.051.in_not => and2.1.in1
net spindle-enable and2.1.out => hm2_5i20.0.pwmgen.02.enable
# enable spindle drive
net spindle-enable => hm2_5i20.0.gpio.065.out
# force spindle lock pin out
net spindle-enable => hm2_5i20.0.gpio.042.out
# release spindle brake
net spindle-brake-prg not.0.out => or2.2.in0
net spindle-brake-logic motion.spindle-brake => not.0.in
net spindle-brake hm2_5i20.0.gpio.040.out <= or2.2.out
#spindle sync
net spindle-index motion.spindle-index-enable <= hm2_5i20.0.encoder.02.index-enable
net spindle-velocity motion.spindle-speed-in <= hm2_5i20.0.encoder.02.velocity
net spindle-velocity => abs.0.in
net spindle-v-abs abs.0.out => scale.1.in
net spindle-v-abs-out <= scale.1.out
# spindle speed
net spindle-velocity mult2.0.in0
setp mult2.0.in1 60
net spindle-abs abs.2.in mult2.0.out
net spindle-rpm abs.2.out
# spindle at speed
setp near.0.difference 0.1
net spindle-velocity near.0.in1
net com-spindle-vel near.0.in2 <= motion.spindle-speed-out-rps
net spindle-at-speed near.0.out <= motion.spindle-at-speed
# trick Axis
net trick-axis motion.spindle-reverse
#end of spindle
JT
26 Mar 2014 21:53 #45281
by newbynobi
Helo Jim,
if you do not use feedback, why do you use a PID? It is not necessary then.
This is a spindle.hal that works with PID and in both directions. (7i43 and 7i40 with DC motor and self made encoder)
wotks within 3 % accuracy! Encoder with 1000 ppr and max spindle speed 3500 rpm
you will need to adapt the PID values to your hardware
My INI has the following values:
# Spindle
[SPINDLE_9]
P = 4.0
I = 10.0
D = 0.0
FF0 = 1.0
FF1 = 0.8
FF2 = 0.0
BIAS = 0.0
DEADBAND = 5
OUTPUT_SCALE = 1.0
OUTPUT_OFFSET = 0.0
MAX_OUTPUT = 0.0
INPUT_SCALE = 1000.0
and for gmoccapy you need to connect than:
hope that helps.
Norbert
# SPINDLE S
# as I do use a 7i43 we will have to load the stuff for that
# you may need to add this to your needs
loadrt hostmot2
loadrt hm2_7i43 ioaddr=0xcc00 epp_wide=0 config="firmware=hm2/7i43/SVST4_4S.BIT num_encoders=2 num_pwmgens=2 num_stepgens=0"
setp hm2_7i43.0.pwmgen.pwm_frequency 100000
setp hm2_7i43.0.pwmgen.pdm_frequency 100000
setp hm2_7i43.0.watchdog.timeout_ns 10000000
addf hm2_7i43.0.read servo-thread
addf hm2_7i43.0.write servo-thread
addf hm2_7i43.0.pet_watchdog servo-thread
# for closed loop we ned a PID control, so lets load it
loadrt pid num_chan=1
addf pid.0.do-pid-calcs servo-thread
setp pid.0.Pgain [SPINDLE_9]P
setp pid.0.Igain [SPINDLE_9]I
setp pid.0.Dgain [SPINDLE_9]D
setp pid.0.bias [SPINDLE_9]BIAS
setp pid.0.FF0 [SPINDLE_9]FF0
setp pid.0.FF1 [SPINDLE_9]FF1
setp pid.0.FF2 [SPINDLE_9]FF2
setp pid.0.deadband [SPINDLE_9]DEADBAND
setp pid.0.maxoutput [SPINDLE_9]MAX_OUTPUT
# ---PWM Generator signals/setup---
# no quadratur counting = 1 else 0
setp hm2_7i43.0.pwmgen.01.output-type 1
# Set the spindle's top speed in RPM
setp hm2_7i43.0.pwmgen.01.scale 3500
setp hm2_7i43.0.encoder.01.counter-mode 1
setp hm2_7i43.0.encoder.01.filter 1
setp hm2_7i43.0.encoder.01.index-invert 0
setp hm2_7i43.0.encoder.01.index-mask 0
setp hm2_7i43.0.encoder.01.index-mask-invert 0
setp hm2_7i43.0.encoder.01.scale [SPINDLE_9]INPUT_SCALE
# we need a scale for feedback to the pid
loadrt scale names=scale_rps_to_rpm
addf scale_rps_to_rpm servo-thread
setp scale_rps_to_rpm.gain 60
net spindle-on hm2_7i43.0.pwmgen.01.enable <= pid.0.enable <= motion.spindle-on
net spindle-vel-cmd pid.0.command <= motion.spindle-speed-out
net spindle-output pid.0.output => hm2_7i43.0.pwmgen.01.value
net spindle-vel-fb-rps hm2_7i43.0.encoder.01.velocity => scale_rps_to_rpm.in
net spindle-vel-fb-rpm scale_rps_to_rpm.out => pid.0.feedback
net spindle-vel-fb-rpm motion.spindle-speed-in
net spindle-index-enable motion.spindle-index-enable <= hm2_7i43.0.encoder.01.index-enable
# spindle at speed detection #
loadrt near names=near_spindle_speed
addf near_spindle_speed servo-thread
# set the spindle speed inputs to agree if within 3%
setp near_spindle_speed.scale 1.03
# connect one input to the commanded spindle speed
# we declared above already
# net spindle-vel-cmd pid.0.command <= motion.spindle-speed-out
net spindle-vel-cmd near_spindle_speed.in1
# and the other input to the encoder-measured spindle speed
# net spindle-vel-fb-rpm scale_rps_to_rpm.out => pid.0.feedback
net spindle-vel-fb-rpm near_spindle_speed.in2
# connect the output to the spindle-at-speed input
net spindle-at-speed motion.spindle-at-speed <= near_spindle_speed.out
# Spindle
[SPINDLE_9]
P = 4.0
I = 10.0
D = 0.0
FF0 = 1.0
FF1 = 0.8
FF2 = 0.0
BIAS = 0.0
DEADBAND = 5
OUTPUT_SCALE = 1.0
OUTPUT_OFFSET = 0.0
MAX_OUTPUT = 0.0
loadrt abs names=abs_spindle_feedback
addf abs_spindle_feedback servo-thread
net spindle-vel-fb-rpm abs_spindle_feedback.in
net spindle-speed-rpm abs_spindle_feedback.out => gmoccapy.spindle_feedback_bar
net spindle-at-speed gmoccapy.spindle_at_speed_led
hope that helps.
Norbert
27 Mar 2014 00:00 #45286
by jbunch
JT,
I am using master. 2.6.0. It used to work with AXIS and 2.5.3 and it used to work with master. It now seems to have problems.
Jim
Jim
27 Mar 2014 06:16 - 27 Mar 2014 06:27 #45292
by BigJohnT
Did you change "anything" between 2.5.3 and master?
The basic G96 test in sim/lathe works fine.
JT
JT
Last edit: 27 Mar 2014 06:27 by BigJohnT.
Time to create page: 0.097 seconds
