Program exceeds machine max. on axis X
19 Jun 2014 09:32 - 19 Jun 2014 11:27 #48107
by krlynn
Program exceeds machine max. on axis X was created by krlynn
I wrote my first program today for a fairly simple handle. It failed execution and I got a message stating "Program exceeds machine maximum on axis x."
Reason was the program included an x coordinate instruction of "6500" instead of ".6500." I 'd gone over the code several times and missed it. When I told linuxcnc to attempt to run the program anyway, it issued a message identifying a problem on line 19. And there it was.
Last edit: 19 Jun 2014 11:27 by krlynn. Reason: Discovered problem
19 Jun 2014 18:08 #48116
by ArcEye
Well done, first stage of Linuxcnc self-sufficiency passed!
Andy and I keep trying to get across to people that error messages actually tell you what is wrong, unfortunately some of them require a bit more knowledge to know what they mean.
Replied by ArcEye on topic Program exceeds machine max. on axis X
The following user(s) said Thank You: krlynn
30 Jul 2016 16:40 #78162
by clunc
Replied by clunc on topic Program exceeds machine max. on axis X
BTW, computer programmers have, since back in FORTRAN days, acquired the habit of adding a leading '0' to make that little decimal point more visible. Recommended.
30 Jul 2016 21:09 #78171
by krlynn
Replied by krlynn on topic Program exceeds machine max. on axis X
Thanks.
